Question about Sony Cyber-Shot DSC-W1 Digital Camera
Light sensor? pictures get a green tone and even the display has become very dark and also greenlooking when you direct the camera to normal uplighted objects.This phenomenon suddenly happened.
  • 2,985 Answers
The CCD is failing - contact customer support - a repair is not likely, but this component has been subject to a recall in the past - there there is a chance of a free replacement -perhaps maybe
Posted on Sep 01, 2007
Showing distorted red toned images
To find out if what is causing this problem. please shoot some pictures and view them on a computer. If the photos have distorted colours on the computer too, the cause is in the sensor.
If the look good on the computer, the cause is the monitor on your camera. Can be caused by lots of different things, like a broken cable, a defect on the display itself, caused after someone dropped the camera and so on.
If you can live with a "damaged" screen, you still could make pictures. If the sensor is defect, consider a new camera. Cameras are becoming better and better and in the same time they become cheaper.
Dec 18, 2013 | Cameras
My pictures vary from normal to too bright and/or too dark
Pictures being too bright normally mean that you have direct light shining towards camera. try to change angle of photo or else compensate with flash or lighting
Dec 28, 2011 | Nikon D40X Digital SLR Camera Digital...
How do i take 12 dark, 12 light and 12 perfect pictures with 400 black and white film on a vivitar 3800n camera?
For normal exposure, set the ISO dial to 400. Meter normally, adjusting the shutter speed and/or lens aperture until the green LED in the center lights up.
For dark pictures, you want to underexpose about two stops. One way is to meter as above, then stop down the aperture two stops (larger F/numbers) or increase the shutter speed two stops (larger number) or a combination of the two. Alternatively, set the ISO dial to 1600 and meter normally.
For light pictures, you want to overexpose about two stops. Meter normally then open up the lens two stops (smaller F/numbers) or slow the shutter speed two stops (smaller numbers) or a combination. Alternatively, set the ISO dial to 100 and meter normally.
You can also experiment. Over/underexpose one stop, then two, then three, then four, and even five. You might want to take a notebook with you and write down what you're doing. Record both the setting and how many stops over/under it is. When you get the film back, you can refer to your notes and see what happened.
Jan 25, 2011 | Vivitar Photography
There are pink tones in pictures Help!
Generally, if you get a pinkish tone with low contrast, it means that your sensor in the camera is shot and will either need to be fixed by a professional or replacement of the camera itself. You'll sometimes also see stripes in the images as well that can alternate dark and light.
Jul 14, 2009 | Canon PowerShot A80 Digital Camera
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Dark image when taking pictures of sceneries
If the pictures show up normal on the computer then the back light for the LCD is going bad...
try to replace the back light..
thank u
rate me!!
May 24, 2009 | Canon PowerShot A550 Digital Camera
My Canon EOS Digital Rebel XT is taking pictures darker than normal. Why?
First, to test be sure you are in Automatic mode. The dial should be on the Green Box setting. If its on other settings its in manual mode and can be set wrong. take a test picture in this mode, If its looking normal, then you were either int he wrong mode or your manual settings were off. But if they are still dark try your ISO settings, if too low a number it will result in dark images. For example ISO 100 is perfect for outdoor daylight, but ISO 400 is better indoors.
Next try the F stop settings and arppreture. If things improve, you have found the issue. This camera is professional grade so it will do exactly what its set to do even if the outcome is not what you want!
Whe all else fails use the menu and reset the camera to factory defaults.
Dec 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Blank view finder fe-190
try switching your camera on in a dark room (do it at night with the curtains closed and the lights off).
if the screen lights up (should still be black or a very dark green),
then the lens or light sensors might not be functioning correctly.
if the screen stays conpletely black, then the actual screen might be damaged.
note- you might need to let your eyes adjust to the darkness before you switch your camera on.
May 22, 2008 | Olympus FE-190 Digital Camera
Sony Cyber-Shot DSC-W1 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
