Question about ViewSonic WR100 Router
Configuration I do not get any screen when I put in my browser
  • 1,113 Answers
Re: configuration
Double check all the steps in th user guide to set up the router. You can download the manual from the link below: You should be connected directly to the router by an ethernet cable. Do you see the led on the router for the port you are connected to lit to show you have a connection? Have you configured your PC to get it's IP address by DHCP from the router? Your address should be Check the status of your PC lan connection in the "network connections" screen. Can you ping the router on If this fails try resetting the router by pressing the small button on the back & try again. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 01, 2007
0 characters
3 Points
How to put a passsword on my router
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-
Jun 29, 2012 | NetGear WGR614 Wireless Router
How to configure my router with laptop?
  • 1.Launch your Web browser and then type in the address field. Click "Enter."
  • 2.Click "Basic Settings." Input the configuration information given to you from your ISP in this screen. The settings not given by your ISP can likely be left at their default value. Click "Apply" before navigating away from this screen.
  • 3.Click "Wireless Settings" in the menu on the left side of the screen. Enter or select the appropriate settings in the Wireless Settings dialog. Select the appropriate Security Options, then generate the security key. Click "Apply" before navigating away from the Wireless Settings dialog.
  • 4.Reboot the router for the changes to take effect.
  • Good Luck, Jopica123
    May 17, 2011 | NetGear WGR614 Wireless Router
    How to configure 3 linksys wrt120n router? please help me... thank you.
    You will want to open you Router configuration to setup security, Simply type in the address bar of your browser and follow the on screen instructions from website. Copy and Paste into address bar. Good Luck
    Mar 25, 2011 | Linksys WRT120N Router
    How do i put a password on D-link
    Connect a LAN cable from the D-Link to your computer's LAN port, open a browserand enter the D-Link's configuration URL. OR open the browser on your laptopand enter the D-Link's configuration URL..
    The default PW = blank (just press Enter)
    You can now change the admin password and/or configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
    Feb 28, 2011 | Routers
    Hello there, need to know how to config a phone line modem Zhone 6381 I guess its called the Zhone 6381-Ax Router. I happen to prees the reset button and losst the programed IP. how can I go about...
    To configure your router, make sure you are connected to it first, open your web browser. Ignore any error about lacking a connection. Type the default IP address ( into the Location field of your browser and press the Enter key. The following screen appears.
    The default user name is Admin and the password is Admin. Both are case-sensitive.
    Note: You should have your PCs configured for DHCP mode (if your router will be), and have proxies disabled on your browser. If you see a login redirection screen when you access the web interface, verify that JavaScript support is enabled in your browser. Also, if you do not get the screen shown above, you may need to delete your temporary Internet files.
    The first screen that appears after the log in screen is the Home page.
    From this screen you can configure the LAN and WAN connections, configure the router's security, routing, and filtering, access debugging tools, obtain the status of the router, and view the online help.
    From here, go to the Setup Tab and click the New Connection on the left.
    Input your numbers and don't forget to save.
    Hope this helps!
    Dec 21, 2010 | Zhone (6218-I2-200) Router
    I am trying to set up a wireless lan access point instuctions tell me to use ip address to bring up configuriation screen
    "your router should be power on to perform this operations". Follow this steps bro. 2.reset your router configurations by pressing the reset button at the back of your router on the left side of the WAN port.3. when you are done pressing the reset button, wait 1minute to secure the configuration to roll back to its default configurations. 4.launch Browser "Mozilla Firefox". your locator bar or URL bar type " or" as a default ip address to log-in to your router at the top of the browser. 6.the authentication box will appear in your screen to input your router security log-in. 7.for user name just leave it blank. 8.for password type admin as a default password. 9.the router internal configuration setting will appear in your screen. enable wireless connection, select "wireless" at the upper menu list of the page. 11.set your SSID any name you want to name for your wireless connection then save. 12.for LAN you can just leave it on its default configuration.
    Jul 08, 2010 | Linksys Wireless-G WRT54G Router
    Secure wireless internet
    The D-Link is configured using a Web browser. After you have connected your computer to the D-Link router, follow these steps: 1. Launch your Web browser. Enter "" into the address bar and press the "Enter" or "Return" key.
    2. A logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
    3. Click "OK". A D-Link configuration screen will appear. All changes to the D-Link configuration are made here.
    Enabling WEP* (Wired Equivalent Privacy) will require anyone wishing to access the Internet through your wireless network to enter a password. After the correct password is entered, a connection is established, and all data sent from the D-Link to the computer and back is encrypted. From the D-Link configuration screen:
    1. Click the "Home" tab.
    2. Click the "Wireless" button.
    3. Click the "Open System" button next to "Authentication".
    4. Set the "WEP Encryption" to "128 bit".
    5. Set the "Key Type" to "ASCII".
    6. Type a 13 digit password into "Key 1".
    7. Click "Apply".
    8. When you connect to your wireless network from a computer, you will need to enter the 13 digit password.
    *Note: If your computer's operating system supports it, enabling WPA-PSK is more secure than WEP. The steps above can be modified to set up WPA-PSK.
    May 10, 2008 | D-Link AirPlus DI-524 Wireless Router
    Web Configuration Screen
    You may have to remove proxy settings on your Internet browser. Or, remove the dial-up settings on your browser. The computer may not have received an IP address. Restart the computer or run the ?winipcfg? utility to dynamically assign the IP address (?ipconfig? for NT users), and then launch the browser.
    Feb 19, 2006 | NetGear MR314 (MR314NA) Wireless Router
    ViewSonic WR100 Router Logo
    94 people viewed this question
    Top ViewSonic Routers Experts
    Robin Hill
    Robin Hill
    Pablo Gonzalez
    Are you a ViewSonic Router Expert? Answer questions, earn points and help others
