Putting main deck line cover back on inside vcr
I took my vcr apart because my tape was stuck inside. This involved removing a metal piece (with no moveable parts) from over top of where the tape sits inside the vcr. It has a stamp that says "main deck line video" on it. I didn't take a photos and am now confused as to which way it needs to be replaced. Should be pretty simple if I had a photo of what the inside of the vcr looks like before anything is taken apart and once the outside is removed. Thank you. Joy
    Problem Solver:
  • 6 Answers
This sounds like the carriage tray, it's the metal plate that the vcr slides in and out. It should have a door on the front side and it may have at least 2 screws and sometimes four. The only problem is aligning up the tray to be exact. in the power on mode the vcr tray should be pushed outward like the tape is sticking partly out of set.
Posted on Sep 03, 2007
SOURCE:
Jvc video recorder. cassette will not eject
make a hard reset and try to eject
Jul 08, 2008 | Cameras
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Won't eject tape.
I had a Sony SLV-N60 VCR that wouldn't eject the tape.
After removing a few large and obvious screws, the I took off the cover. Inside, on one of the white plastic arms (not really an arm, but a moving part), there was a piece of junk, looked like part of a popcorn hull or something. I took that out, and for good measure, vacuumed out the rest of the chassis. The lubrication looked good, so I left it alone.
After doing that, the tape ejected perfectly. I put the cover back on, and it still works.
Apr 17, 2009 | Televison & Video
The pump catch on this machine
That is a pump clean out. Yes water should be there, and i would try to retighten it before i used tape. Hope you didnt put it back cross threaded.
Jan 23, 2009 | Siemens WFXD5200UC Front Load Washer
Vcr tape stuck in unit
Marvin,
I am not registered here as an expert, so there should not be any charges. I do not have the option of chatting I am guessing only the registered experts have that. Here goes: 1. Take a phillips screw driver and remove all the screws that are holding the case on, there will be some big ones on the sides and a few maybe smaller ones on the back. 2. Lift the the case off 3. You should see the tape on the inside the vcr 4. You may or may not have to remove some of the metalic shielding which should be only anywhere from 4-6 screws if you have a piece of metal directly over the vcr tape some have them some do not. 5 Gently pull the magnetic tape up from around the feeder posts and the drum. 6. Try and work the vcr tape up and out, If you are having extreme difficulties with this try plugging the vcr back up and pushing the eject button while still holding the magnetic tape. The tape should eject now and you and carefully pull it out. 7. When you get the tape out, use your thumb to push up and turn one side of the white reals on the tape to slowly wind the magnetic tape back inside the tape. 8. Unplug the vcr again and replace everything that you had to remove and replace the cover.
I hope this helps and let me know if you need further assistance. And since I am not a registered expert here there should be no charge for this help unless you chatted or got help from one of the registered experts.
Jul 05, 2008 | Samsung DVD-V5500 DVD Player/VCR
Go video gv6060
check the drive belt - it's probably stretched and won't operate the mechanism to eject the tape.
Nov 27, 2007 | Rio Go Video GV6060 Dual Deck VCR
Tape stuck and tv turns off
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Jun 01, 2007 | Sylvania 6313CB 13 in. TV/VCR Combo
TV shuts off when VCR tries to eject cassette
This is a hard call man. Some combos have to be laid down when taking the back off or it will collapse when you do take off the back, falling over backwards as they are top heavy. These units are so tight inside by means of no room to work so alot of maufacturers have extension cables to attach to componets ie vcr deck and main chassis. After they take them apart. If you really feel confident then lay the set down on its face and take off the back and after the back is off look to see in the deck part if the tape has come out of the cassette or if it all looks normal. If you see the tape out of the cassette ,cut off the tape on both sides and see if the tape will eject. It it does then go back in after and remove the remainder of the old tape. Now it could have been a bad tape but most likly something is wrong with the mechanism. If you cant see anything out of norm, dont try to force the tape out as you WILL cause more damage and most likely unrepairable. Really there are no user serviceable parts inside these buggers so the best advise I can give ya is to disconnect the thing and take it into your repair shop for an estimate!! Good Luck
May 23, 2006 | Samsung CXJ1964 19 in. TV/VCR Combo
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
Ekse
