Question about SMC Barricade g SMC2804WBRP-G Wireless Router
Stopped connecting to the internet
Doesn't allow intetrnet connection anymore. pinging shows everything connected. When removed from the circuit and computer hooked directly to modem, internet connection is achieved. I have power cycled and reset the router. I have also replaced cable wire. All led's show correctly. I can reach the admin setup menu. Any suggestions for fixing this problem would be appreciated.
  • 1 more comment
  • thomas123 Nov 11, 2007
    sounds like the same problem we're having. the internet slowed down and then stopped working completely becasue fo the router. any suggestionis?
  • archone Nov 20, 2007
    Same problem. The host machine shows two IP addresses for this notebook in the house. The notebook itself cannot seem to find the IP address, instead it picks up neighbour's Unsecured wireless IP address.
    How do i delete the two on the host machine?
  • Anonymous Mar 15, 2008
    cant connect to internet when router is connected
  • 196 Answers
What kind of connection do you have? (Cable, DSL, etc.) Post an ipconfig /all result (Run, cmd, ipconfig /all) Delete your current connection and re-create it.
Posted on Sep 03, 2007
Internet connection failed
Are you sure is your motherboard? Verify if you have connection by going to Start/Run/cmd/ping xxxx.com -t as continues ping, if it coming back with a reply you have connection if it doesn't call your provider and explain your situation.
Aug 30, 2011 | Computers & Internet
Unidentfied network is connected, no internet access, i see a chair between the internet acces and the laptop. tried to reboot everything several times, turned off firewalls, nothing helps/
That unidentified network, have you connected to that before and browsed the internet? Just because you connect to a network, doesn't mean that network is setup to allow internet access. It could be a simple fact that you need to connect to a different network.
Jun 30, 2011 | Computers & Internet
I am unable to browse iternet, it showing massage that cannot connect for an unknown reasons please check your internet setting and change them if needed . currently i am using htc touch diamond (cdma)
There could be many reasons for your problem.
1. If you use proxy server, make sure the server and the service are up and running
2. If you use proxy server check the Internet options and look for the correct values in the required fields.
3. If you use wireless router check the connection to the router.
4. If you use router check the network configurations. Many of the routers have internet connection test. So login localy to the router interface and check the connection.
5. If everything above is correct try pinging a website from cmd. Open command prompt Start->Run->cmd. Write the command "ping www.google.com" (without the quotes). If you have ping look for application that blocks the http traffic on port 80. If the result is "Request timed out" try to ping 209.85.148.104. If you cannot ping any site or computer outside your network, then you have to call your provider.
Mar 01, 2011 | Computers & Internet
HP Laserjet 2015dn (network printer) does not print. Cannot ping it's appointed address anymore, therefore cannot open a web page to it.
Remove and reinstall the printer in your control panel. If the network printer is online and available and the network at its location is not having access problems then this should solve the issue and allow you to resume printing again.
Make sure that your computer is still connected to the network correctly. Go to network connections from your desktop or through your control panel and see if it shows your computer connection as available without problems. If you find an issue in this area or your connection shows other problems, re post and clarify your findings and I will help you solve this issue right now.
Sep 27, 2010 | HP LaserJet P2015dn Printer
Aspire 5670 wifi issues. I am showing that I am connected to the internet but unable to connect to net request is timed out. ipconfig shows address. ping yahoo .com request timed out.
Bring up the browser window, don't worry that you can't connect. If it is IE, look to the right upper and choose the drop down menu "Tools". Scroll down and choose "Internet Options", Click on the "Connections" tab. Scroll down the bottom half and click on LAN settings. Make sure that everything on this page is unchecked. If there are checks present, clear them, hit apply and ok.
If there were no checks anywhere, then you may have to go the "device Manager", scroll down to the network devices and uninstall them one at a time and reboot, thus allowing Windows to recognize them and load a fresh driver.
Sep 18, 2010 | Acer Aspire 5670 Notebook
My computer shows connected but I can't get online I have a wireless netgear card in the laptop and a linksys router. I can see the network, and the computer shows connected with the icon at the bottom and...
check that u have properly configured ip address
gateways and dns
try pinging gateway if u get ping then try pinging ur dns servers.
if u get ping from dns server ur brouser might got curropt if not you need to reconfigure ur wireless router.
Feb 06, 2010 | NetGear (IM-WG511T) Wireless Adapter
Internet connection shows its connected but cant get on the internet
try using a DOS window and type the command ping www.google.com to see if you get a response, this ping command allows you to see the connectivity , if you get a successful pinging then the next step would be to find out if you have a norton internet suite or some other firewall or protection measure between your computer and the internet. also whether you have a cable modem or FIOS router it would be savy to connect the pc directly to the router and unplug any other computer you may have connected. some worms or viruses can prevent your computer from getting to the internet so you cant fix the problem, although everyone discards a physical problem in this case I always bring my own working ethernet cable just in case. actually I always carry two or three patch cords to make sure the problem is really software related and not media related. try posting the output of the command ipconfig/all in some site like pastebin or similar. thank you .
Jan 26, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Internet connection?
go to file in your browser and see if you have a check mark beside work offline if you do click it to get rid of check mark
Jan 30, 2009 | Mozilla Firefox
Internet wont connect
Try leaving both modem and router off for 10 minutes. Turn them both back on and leave them alone for 15 minutes, does it work now? If not, make not of all of your custom settings (if any), try resetting the router back to factory defaults, restore any custom settings and try again. I had the same problem with a linksys and it worked after factory reset.
Sep 01, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
SMC Barricade g SMC2804WBRP-G Wireless Router Logo
57 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
