Question about Symphonic ST419E TV
Remote sensor not working
Thought the remote was broken, bought a new universal, works now and then. Discovered no remotes work with our tv. Looking for a solution to operate the tv channels without remote. We can change the channels but cannot get to "Game" to watch a dvd or play video games.
  • Anonymous Dec 15, 2007
    need to know how to operate or switch the tv to dvd mode.
I took advise from this site and fixed my tv, Thank you very much. Yahoooee
Posted on Nov 21, 2007
I had a similar problem ... As a last ditch effort I decided to open the back of the remote: 1. I removed the two top screws only (I have a torque screw set) and cleaned the sensor w/ a soft cloth ... 2: I then sprayed a can of air through the opening as I could ... re-aligned case and secured screws. It is now operational again. If this doesn't work check for capatible remotes.
Posted on Sep 06, 2007
Problem with remote control or TV sensor? (Sanyo lcd32xr8da)
From your detailed description, I assumes that the infrared sensor inside your TV has the fault. This part can be loacated just behind the infrared sensor window at the front panel of the TV. You have to open the TV, and desolder it out from position, note the type used, and repalce it. There are so many types of these. Pictures of some are attached here.
Jun 12, 2012 | Sanyo Televison & Video
My Scott Remote Control #KC01-B1 one night just would not connect to the sensor in my tv. I thought my batteries were low and changed them. The remote would still not work. I went to a Radio Shack...
Before you throw any more money at this problem, have you considered that the problem might be with the Infra-red (IR) receiver in the TV?
Also, did you programme the correct codes for your Scott TV into the universal remote/s? If you can let me know the model number/s of the universal remote/s - and you still have them - I can probably verify the codes and the programming instructions.
Hope this helps.
Oct 16, 2010 | Scott LCT37SHA TV
Remote Stopped Working
It is possible the IR sensor is bad. Most of the time if it is a remote issue, the light on the remote will not light up. Does the remote that came with tv still control any functions? I would try the remote that came with the tv, and then go from there, but it sounds like your IR sensor has gone out on you.
Mar 31, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv sensor not working ????
Press and hold down the up volume button on the original remote, look at the light (led) on the remote, the light should be lit and slightly pulsing. If no pulse your remote is bad, if you are seeing the pulse try cleaning the ir window on front of tv. Let me know if this helps and please rate this solution. lone99star
Jan 11, 2009 | Sanyo DP42746 42 in. Plasma Television
Tv won't recognize remote codes
If the manufacturer of the universal remote cannot give you codes for the Symphonic you are out of luck. U will either have to get an original replacement or get a Harmony universal remote.
Jun 25, 2017 | Universal Remote Control Remote Control
Cant find the code to program the RCR311W to run my Philips 19ps45s.
If you can return the remote, I'd pick up a harmony remote from Logitech (they all work fine). It doesn't use codes, just the model numbers of the device. They support 55,000 devices and I have never found a device that they won't control (sorry, I know this isn't the advice you were looking for, but this will make your life easier).
Mar 11, 2008 | Universal Remote Control DIRECTV Universal...
Remote randomly works. 27" Symphonic TV... but remote works on other Symphonics in the house
I would get a new remote control first. Just because it is the same brand doesn't mean the same reote codes are used.
Apr 05, 2007 | Symphonic ST419E TV
My remote control does not work
You could have a defective IR sensor in the tv set that sends the infared signal to the MIcroprocessor IC. These are something you cant just replace, as it needs to be trouble shot with a scope to see if theres a data signal comming out of the sensor and if there is it could be a bad solder connection somewhere between the sensor plug to the Main IC. Also could be the B+ that supplys voltage to the sensor. Unless you have had electronic repoair experience, You should have a pro assist you with this repair. Sorry I couldnt assist you more with this . Good Luck
Jul 06, 2006 | Toshiba MD20FN3 20 in. TV/DVD Combo
Symphonic ST419E TV Logo
137 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
