Toshiba V3100 PC Desktop
Problem for Toshiba V3100 PC Desktop
Installed new memory modules can get to the toshiba post screen
By ColeJay on Apr 02, 2009
The system recycles to the Toshiba screen for access to bios
Comments:
Apr 06, 2009
- Thanks for your suggestion jutkin. I'll try this and get back to you
Apr 07, 2009
- Thanks again jutkin. I tried your first suggestion and successfully identified one bad 128Mb memory module in a set of two used ones I had purchased. The max memory for this system is 256Mb so I was able to use an old 128 Mb module I had on hand to boot up and see that the system recognized all the RAM. I am a rookie with this stuff and really appreciate the practical help.
Best Solution
posted on Apr 02, 2009
Helpful)
jutkin
Rank: Wiz
Rating: 86%, 31 votes
Two ways to approach this.
1. try 1 stick at a time and see if you can boot and the system is working,
2. Download and run memtest to see if you got bad memory.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Aug 20, 2009
Not Rated)
gherna1
Rank: Guru
Rating: 86%, 55 votes
The symptom is telling you that either the memory you installed is either of the wrong type, incompatible, or is not sitting properly in its socket. Please check your user's manual for the exact type, speed, etc.
If you've added a second module, ensure it is of the correct type, even if it's not of the same size. Some laptops take increments well, eg: You can add a module of 512MB to an existing 1GB module. My Dell Inspiron 9100 does.
Using the same type gives you the double-buffering benefit provided by newer memory modules. A different type memory module may work, but it will not give you the benefit of faster memory access, if it works at all.
Was this helpful?
Yes
No
Popular Solutions for Toshiba V3100 PC Desktop
Questions and Unsolved Problems for Toshiba V3100 PC Desktop
Do you recommend Toshiba V3100 PC Desktop?
Answer
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Answer
connecting to the Gnutella network with Bearshare 5.2.5
Answer
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP... (More)
Answer
adr=610c Abort program code error 6193
Answer
i have a casio pcr t-2100 and i want to program multiple plu keys in one dept. How do I do that?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba V3100 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
