Question about Hotpoint Ultima WF865 Front Load Washer
Changing rear drum
Hi would it be possible for you to send a diagram of how to change the rear drum on the wf865 hotpoint washing machine please i need to do this and i have looked for iagrams but have been unsuccesful many thanks kat
  • kittykat7412 Sep 01, 2007
    yea i have tryed that do i have to remove anything from the inner drum ??
  • 183 Answers
I presume you mean the inner drum, this is major strip down, remove the top, remove the front panel and the control panel, remove and split the out drum in half, remove the drum pully, refit the nut and hit the spindle with a hammer using the nut to protect the thread, this will force the drum spider out of the bearings, reverse the process to reassemble. Regards and good luck Advisor
Posted on Sep 01, 2007
Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 23, 2010 | Hotpoint Ultima WF865 Front Load Washer
How do i fit a belt to hotpoint washing machine WF865
*********** unplug from mains************** top cover off ....rear cover off ....remove old belt belt new belt on lower puly feed it on to larg pull turn at same time ************WATCH YOUR FINGERS ********THEY CAN GET CAUGHT EASY******* done .put covers back on ...
Dec 30, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Dec 14, 2009 | Hotpoint Ultima WF865 Front Load Washer
Cycle does not finish door wont open error code f05
F05 means pressure/\waterl level switch is jammed on full.
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Please leave feed back
Nov 12, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WF865 Child Lock Button Stuck 'On'
you should be able to turn it off by holding it in for a while longer,5-10 seconds, unless the circuit board is at fault.
Jan 07, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Aquarius WF 430
Best way to check if the main drum bearings have gone is to;
  1. Remove back panel of washer
  2. Remove drive belt.
  3. Spin drum by hand from the inside of the drum, if it feels rough, or is noisy and rumbling, then the main bearings have gone.
If there is no apparent noise, then you will have to investigate further.
If I can help further, pleas let me know.
Plz rate my solution.
Oct 31, 2008 | Hotpoint Ultima WF865 Front Load Washer
WF865 noise when spinning
Washers have to be balanced. Some have balance adjusters either inside the dryer as explianed above or on the bottom to level the washer. try to balance it by turning the bolts slightly or the bottom portion of the washer to level it. Or else they want to shake apart. Also by distributing the clothes evenly so it won';t be all to one side can help. do not tighten the screws all the way. Just tighten them to the point of getting the right balance.
Jun 16, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WF865 Drum getting stuck?
Feb 08, 2007 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
142 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
