It dont leak but i can press on the bars with just a little force i can bottom out the forks. what should i do to resolve this issue?
This is an old thread but just in case you haven't gotten the problem fixed, you need to change the fork oil in your forks. The main reason is to make sure you've got the correct amount in them.
If after changing the oil they're still too spongy, you need to change the oil to a heavier weight oil. Use 30 weight "FORK OIL". Do not use any other type of oil as it may foam. Use fork oil only and in the correct amount. Your owner's manual should tell you how much oil to add.
To drain the oil, there is a plug down near the axle on each fork slider. At the top triple trees, there is a large cap on each fork tube. Take this out and add the proper amount of the proper weight oil. Only do one tube at a time. You may have to get the weight of the bike off the front end.
Type E is about 7.5 weight I use
15w and it's very stiff. You maybe low as well. Like the other said check the book. My 95 FLSTN is
11.5 oz wet
Do u use heavy duty (screamin eagle) fork oil ? Whens the last time u changed it ?
has it always been this soft or just started?
