Question about Acer AL1916W 19" LCD Monitor
Acer LCD 1916 brightness spot
Hi. I just bought the 1916 LCD flat screen and I have a question. When the screen is on, but the pixels are set to black (when you turn on the computer or even if you put a black wallpaper), I can see a brighter spot in the center of the screen. Like a blurred area which is a bit whiter. I wanted to know if this is normal or if there is a slight problem with the screen. Thanks a lot, Kev
I have a COBY 40 inch LCD television and the pixels leave a liquid like spot is that pixel damaged? And in the center of the screen is a long black line also pixels is that repairable, estimate cost?
The actual lcd is not repairable. It sounds as if it is damaged. Unfortunately the cost of the lcd is probably more than what the set is worth.
Aug 18, 2016 | Coby Televison & Video
Tip
Why the white or black spot on LCD Display
Dead and Stuck Pixels <br /> Pixel defects for an LCD monitor are defined as one of two types: dead or stuck. Technically, both types of pixel defects are stuck pixels but it really deals with the electrical currents and the state of each pixel or sub-pixel. <br /> A dead pixel is defined as a pixel or set of sub-pixels that has failed and is permanently in the off position. This condition means that the pixel will not let any light through. This can be observed as a dark or black spot on a brightly colored or white background. <br /> A stuck pixel is defined as a pixel or sub-pixel that has failed and is permanently in the on position. This can be either with a single or multiple sub-pixels for a given pixel and is best observed on a dark or black background. A white pixel means all three sub-pixels have failed while a green, red or blue pixel means one of the sub-pixels has failed. <br /> Hope this helps, if so do rate the Tip
on Jan 16, 2011 | Televison & Video
My tv screen has a black spot
HI,
Are you sure that there is balck dot on the sreen. Check one more time is it any dust on the screen.
Black spot Means pixel of the Lcd sreen is fault. There are thousands of pixels in an lcd screen. when any of the pixel or a group of pixels become faulty the black spot will appear. Its not possile to rectify the problem other than replacing the LCD panle if its avilable. The avilability of lcd screen is very rare.
Ajin
Jun 16, 2012 | Emerson EWL20D6 Television
My brand new LG 37' Led/Lcd t.v. had four very light white spots that you can see in the background what causes this?
Hello
Hope this helps, if so do rate the solution
Jan 16, 2011 | LG 37LC7D 37 in. LCD HDTV
Flat panel TV shows a bright pinpoint of light in dark scenes
maybe or maybe not. It is a pixel that is stuck 'on' all the time. Not a warranty claim item as a few bad pixels are allowed.....
It does not spread, but that is not to say that another pixel somewhere else on the screen will not go bad.
Mar 26, 2010 | Sylvania LC225SSX LCD TV
Desktop scree showing white bright spots
The bright spots which you are seeing my be the failed pixels on the screen.
Once connect the external monitor to the notebook and check the display on the external display.
If you don't have external monitor, then restart the notebook and Press F10 or F2 key to Enter into BIOS. If the screen is same with bright pixels in the BIOS screen, then the it is confirmed the issues is with bad pixels.
If your notebook is under warranty, then HP will arrange for mail-in.
Note: There is Pixel policy from HP, go through thebelow URL:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00288895
Aug 03, 2008 | HP Compaq Presario v3000z Notebook
White bright spots on screen
These kind of patches or spots are called as Dead Pixels.
If you find any thing that doesnot change colour along with the other part of the Display according to the image, those spots are referred as Dead Pixels where the LCD needs to be replaced.
Contact your nearest HP Authorized Service Center and find the cost to get the LCD replaced.
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
Monitor
hi if your pixel is permanently brigthing you can try to press gently on the screen on the bright dot to expanse the liquid, sometimes the pixel freeze on lcd monitor.
hope this helps
May 22, 2008 | Computers & Internet
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
268 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
