My toshiba tecra boot on but wont read hd. It says PXE-E61: Media test failure, check cable. PXE-M0F: Exiting Intel PXE ROM. Insert system disk in drive. press any key when ready. I have tryed several hd and it says the same thing. when i try to install win xp it says that there is no hd. can someone help please. thanks in advanced ozz
It could be that the the HDD controller on the motherboard is gone, that's why it does it with several HDD. By the way go under the BIOS and check the Boot sequence, make sure that HDD is first, because pxe error occurs when you select to boot the computer through a network device. If it doesn't find it, that's what it shows on the screen, it can find the MBR.
SOURCE: Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
SOURCE: Trying to start my computer
http://www.hitachigst.com/hdd/support/download.htm has a Disc Fitness Test programme. It produces a floppy to boot from DOS into Windows. My Satellite 1110 has the same error message, PXE-E61. The BIOS shows "no HDD". The DTF found no fault on the HDD. (full test took 45minutes) Give it a try. I know, you need a working computer to down load it-- and DOS and a floppy drive on the faulty one. There are USB adaptors for floppy drives. Tomorrow I prise the 1110 apart and will clean all the cable and connectors. Good luck. Bryan
SOURCE: PXE-E61 : media test failure,
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
SOURCE: PXE-E61 : media test failure, check For Realtek
Are you on a company network ?
As I said if you are, then booting from a network may be part of your company system.
If it is just a home computer then you have other issues which could range from something as simple as a faulty hard drive cable to a dead hard drive.
If it is a company computer on a full lan then turn boot from network back on and see if it will boot. if not then te server that has the boot source may have an error or the lan may have issues.
Thanks. but it dint fix the problem. in the bios it has hdd-cd-lan-usb. Ill keep trying to find the problem.
