Question about Kenmore 64702 Top Freezer Refrigerator
Doors not sucking closed
The door seals are not sucking shut tight. When you close the ref. door the freezer door poofs open and vice versa. The warrenty was up in March. It gets cold but I know this is not right & the door on freezer has stayed ajar once creating a thaw.
  • 183 Answers
Re: doors not sucking closed
This is not a fault but it is a design problem that cannot be resolved, the problem occurs because between the fridge and the freezer there is an air duct to allow the freezer air to be blown into the fridge however when you close the fridge door this forces the air back into the fridge, the result is that it is forced into the air duct and pressurises the freezer or visa versa and pops the door open to allow the compressed air to escape. soory no cure to this one. Regards Advisor
Posted on Sep 01, 2007
0 characters
3 Points
Refridgerator door shutting causes freezer door to open
Check for a draft connecting main body to freezer body, theory is air compression transfer from main compartment to the (smaller) freezer compartment. also a quick fix would be to add more magnet strip or bare the metal that makes contact to the magnet strip that seals the door, if its a latch, Inspect the surface area that locks the latch to mount. Draft checking is achieved by blowing a fan into the smaller compartment, vice versa and having strands of string hanging around in the opposite compartment, if the string nudge indicates an air passage point. Also, check the level of the fridge, if the fridge is uneven (assuming the front is tilted downward) the momentum of the door closing will push the fridge backwards and whip it forward effectively opening the freezer door.
Oct 14, 2011 | Refrigerators
Every time the top frig door is closed the bottom freezer door opens sometimes only 10 or 15mm so that the alarm does not detonate. The reverse also happens, ie top door opens when the bottom door is...
There is an air duct that connects the fridge to the freezer. When the opposite door is closed air is trapped and forced out the other door pushing it open.
The door seals contain a magnetic strip that hold the door to the fridge, these magnetic strips have lost their strength, to test this use a shhet of paper. Open the door, place the sheet of paper across where the door closes, shut the door, then slide the paper out. If the paper comes out without any resistance then the door seal needs to be replaced.
Mar 31, 2011 | Fisher and Paykel E522BRXFD Stainless...
Maytag ref top freezer door pops open when frige door is closed and freezer door does not close all the way
ck the cams on the door hinges also the door seals may not be strong enough and need replacement . mm
Aug 10, 2010 | Refrigerators
Doors won't stay closed!
Frost in the rear of freezer possibly caused by door staying open.  Door staying open possibly caused by frost buildup on ref door track.  Start by making sure the teeth on the freezer track are clear of ice and frost.  This should allow you to shut the freezer door.  Next check the freezer seal.  If it is not completely sealed it it will build up frost. It is also possible that the frost in the rear of the freezer is from a failure in the defrost cycle as the evap coils are at the back of the freezer. If this is the case your refrigerator is probably getting warmer.
Oct 25, 2009 | LG (LRBC22522ST) Stainless Steel
Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 16, 2009 | GE GTS22KBP Top Freezer Refrigerator
I always have icicles in the freezer and anytime we close one of the doors the other comes open and then closes again
Door gasket defective, check for proper seal around door (gasket should be flush against frame when door closed). Also other possible cause is that when you close the door to the ref, the freezer pops open just enough to cause ice to build up around door. Check drain plug inside evap area of freezer, and repalce door gaskets.
Oct 01, 2009 | GE GTS22WCP Top Freezer Refrigerator
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer door pops open.
normal operation actually, gaskets are designed to seal door closed not to hold them closed, first off check the items on the shelves make sure nothing stick to far out preventing good the refrig should be tilted slightly back. to aid in the doors swinging closed( the should close automatically form 45 degrees.)ok for them to "pop" open so long as they close back shut. this works on top freezers and bottomr freezer refigs, sidex sides use a differnet system of closing, if htats the case look into replacing door closures(cams) located under hte door assy
Mar 04, 2008 | Refrigerators
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Kenmore 64702 Top Freezer Refrigerator Logo
460 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
John Tripp
John Tripp
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
