When i rev engine white smoke comes from the exhaust and there is black soot coating exhaust. has 147000 miles i just bought the car. what could be wrong please help and please say how much it would cost to fix.
What is wrong is you bought a worn out motor
with 147,000 miles
White Smoke is usually a bad head gasket
In your case it sounds like a really rich fuel condition
where you spit out a lot of fuel on start up.
I won't go into how to diagnose the many issue it
may have,it would take too long & unless you say you
have experience then only a repair shop would be your
answer to at least diagnose the issues
Just think about the cost question
Your on the internet talking or asking people
all over the world with different currency to answer
your question
You also have no idea what is wrong,so no dealer or
shop would know what the end cost will be.
There are no set prices from one shop to the next,
for anything & for good reason.
Your in charge of the education process,asking questions,
& authorizing whatever you choice to do with the car & it's
problems
SOURCE: White smoke coming out of the exhaust when starting the engine?
Its the problem of oil.The oil is getting burned out. The vehicle is either burning oil or it is moisture in the gas chamber if you notice white smoke from the exhaust. This is a common possibility.but in some cases this white smoke is not due to oil burning.In that case
White smoke from the exhaust is a symptom of coolant entering the combustion chamber. Normally this is a sign of a blown head gasket or cracked head. And this is not a common problem must be repaired immediately. You must STOP driving this vehicle or you will cause serious engine damage. you will have to get both this possibilities checked.
Thanks. you can rate this solution and show your
appreciation.
SOURCE: Nissan Sentra 2000 model. Thick White smoke coming out of exhaust
White smoke is caused by coolant or water coming out the tail pipe. There is a chance that the white smoke was caused by water splashing up from a puddle onto the exhaust pipe. Keep an eye on the coolant level in the radiator in any event.
Let us know how it goes or if the problem persists. We're looking forward to how things go for you.
Is the car runnig little rough on cold start up in themorning for few seconds?? Because I have done quite a few headgaskets on QG18 Sentra aka 1.8 liter nissan sentra. here is the test. Fill up your overflow bottle to the full mark and check the coolant level in about 5 days.(drive it normally as if nothing is going on) If the level is down, your head gasket is gone. How about the check engine light , is it on?? post results.
SOURCE: thick white smoke coming from exhaust
If it looks like a James Bond movie, you have a blown headgasket
SOURCE: white smoke coming from exhaust when accelerating
This is usually an indication of a bad head gasket.I gasket. The white smoke is the coolant leaking out of the engine and winding up in the oil passages, due to a bad head gasket. To confirm this,
1. check oil. Is level increased, or milky appearance?
2. Is coolant level dropping, but u don't see any signs of leaks?
The above indicates a bad head gasket, causing the white smoke u describe. Let me know how u make out.
Motor is not worn out at 147000 i know plenty of people with the same car that have 220000+ im hoping its not the head or head gasket and its just the ECTS (engine coolant temp sensor) is that possible?
Stop asking questions. Your just guessing & worrying yourself for no reason The car has to be properly diagnosed,you know that & you know a brand new car can break down so what other people have or had is of no value to you. You new car has problems find out what they are we have no way to know from here
