Question about SanDisk Sansa m230 MP3 Player
Cannot make it turn on, or do anything
I've only had my sansa MP3 player about 2 weeks. It's battery was low, and it has the rechargable kind, so I pluged it in. Now, When I try to turn it on, it says SanDisk then goes black again, and nothing happens.
  • Anonymous Mar 29, 2009
    it dont no how to turn it on
  • bst_rcky Apr 22, 2009
    I have the same problem. I also got a Sansa m230 mp3 player the other day. Here's my situation---it won't turn on when I press menu like say the Sansa Version03.02.04A does. Why does it do that?
Yea I had the same problem. Do you have one of those "Music Power Duet" thingies that you plug into the wall? You can also charge the Mp3 player off of that and it sometimes works. If not, just use a screw driver to take the back off and get the battery out for a few seconds and put it back in, unless you don't have a narrow screw driver in the first place.
Posted on Mar 29, 2009
Charge the battery-- AFAIK, it won't charge via USB.
Posted on Sep 11, 2007
SOURCE:
Help. i connect my sansa clip mp3 player to my pc it says "connected" then i leave it there for 6 hours while im in computer then its still charging and it never ends.... its supposed to make that? another...
you are spoiling the battery.you should not charge it to 6hr,well 1hr-2hr is very suffiecent.
problem with your battery.so use it and recharge it when it says low battery.
recharge it only 2hr not more than that.
Jun 19, 2009 | SanDisk Sansa Clip MP3 Player
Battery Low Message - Won't recharge
did u try connecting it to your computer like i do mine
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e280player turn on problem
when you plug it into a charger it should power on.
Jul 11, 2008 | SanDisk Sansa E280 MP3 Player
Nothing happens when ON switch is pressed.
Have you tried recharging the MP3 player? I too have a Sansa Clip which I play in the car so I don't often see the "battery low' message, but when I recharge it the MP3 player works again. I understand it takes longer to recharge from the computer so I bought a recharger I plug into the wall.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
hii
just re plug it and see what happens or.. if you have wall mount charger with a usb connect .. then us it ... and if all fails... open ur player and disconnect the batter for a minute and reconnect it and then put it to recharge...
let me know what happnes..
tc
May 28, 2008 | SanDisk Sansa MP3 Player
Charging the battery on a sansa mp3 player
recharge it by plugging it in to the USB port. your sansa should have come with a USB cable and the ports are pretty easy to find.
almost all types of earbuds or earphones are compatible with the sansa system, so if you just go out and buy some you should be fine.
May 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa E250 Battery Low always when charged fully
is it connected properly?there should be a green line going back & forth on a "battery" if the battery is no good,theyre cheap on Ebay.Make sure its new,check shipping costs as they vary.Open up the back-4 screws.Lift out battery.FULLY recharge.Very easy.
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
191 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
