Question about Eclipse CD5000 CD Player
Cd will not eject.
There is someone else with the same problem on the post but it is unanswered. The face plate comes down and goes back up without ejecting. it is new. It came with the car that I just purchaced. I do not have the owners manual either. ugh! been listening to the same damn cd forever and it's starting to suck.
3 Suggested Answers
  • 3 Answers
SOURCE: eject
If you remove the deck, turn it upside done it is likely you will see a piece of clear plastic that holds the gear assembly together. usually fractures at the back of the deck where a screw go's through. if this is the case let me know & i will advise how it can be repaired..
Posted on Feb 08, 2008
SOURCE: eject button will not eject cd
Mine was stuck in there for almost a year until I disconnected the battery (for other reasons) and when I reconnected it, the CD finally saw the light again.
Posted on Mar 29, 2008
  • 15935 Answers
SOURCE: How do you eject the damn cd out of the pioneer DEH-P7900BT
Your Manual
will go over all the functions in detail.
3 EJECT button
Press to eject a CD from your built-in CD
Press and hold to open or close the front
Bottom rightmost button.
Posted on Jan 02, 2009
0 characters
1 Points
There is no display on the faceplate. The faceplate is stuck in the CD eject position. If I remove the faceplate the mechanism rotates to the position where the controls would be visible but when I attach...
I would try cleaning the connectors on the face plate with an pencil eraser and on the unit itself with a very fine sand paper. And make sure you get rid of any dust after cleaning before putting the face plate back on.
Please leave me a good feedback.
Jan 06, 2011 | Kenwood KDC-8021 CD Player
My 9855 alpine will work when you take the face off / and put it on but the buttons don't work but you can control it with the remote,and when you hit the eject the face wont come down and it wont eject a...
had the same problem with my alpine, i was able to fix it once by, popping off the face plate and with fine grit sand paper (lightly) sand the connection points on the radio and the face plate, then put a little bit of dialectic grease on it . also doing a reset on the unit helped me from time to time...
May 02, 2010 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
I got a Alpine cda-9851 cd player today. I popped the face plate off to see where the cd goes in, but theres not a slot for it! Do i have to have a 6 disk changer for it?
this is a motorized deck. just press the eject button and it should open. the eject button should be on the lower right hand corner of the face.
Dec 10, 2009 | Alpine CDA-9851 CD Player
I dont ehere the cd goes
Press the eject button (lower right corner) and the face plate will drop down, showing a cd slot.
May 31, 2009 | Alpine CDM-7861 CD Player
How do ya work this thing?
Press the SOURCE button "Bottom left of Row"
Aug 30, 2008 | Sony CDX-R3300 CD Player
Pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
May 20, 2008 | Pioneer DEH-P9600MP CD Player
Face plate won't open far enough to insert a CD
try to hit slowly the faceplate in the left side until its open
Mar 08, 2008 | Pioneer DEH-P80MP CD Player
DEH-P690UB Wont Eject or Open
Push the button on the top right corner. It is a little black button that pops out. This should allow for you to bring down the face plate and you can then insert a cd. Hope this helps, also can you please rate my answer. Thanks
Oct 01, 2007 | Pioneer DEH-P690UB CD Player
Car Audio Receivers Logo
Top Eclipse Car Audio Receivers Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an Eclipse Car Audio Receiver Expert? Answer questions, earn points and help others
