57 Other Users Have The Same Problem - Continued
Comment by morris027, posted on May 05, 2009
i have the ipod apple 30 gb classicand i cant get it to sinc to itunes
Comment by jprice667, posted on May 02, 2009
identical to op's problem, the computer won't find the device, it won't sync, etc.
Comment by orionwolf_94, posted on Apr 06, 2009
whenever i plug my ipod into my cpu after like 5 seconds it automaticlly ejects anddiconnects and whenever it does stay connected it never syncs the songs n the itunes or sync at all what the deuce is the problem i just got it yesterday and its alredy crapped out (sunday april 5)
Comment by Guest, posted on Apr 05, 2009
i plug my ipod in and wanna put more songs on it and when i go to sync it where im supposed 2 click inst highlighted to click on it. I have deleted itunes installed it again restarted my computer and every thing i can think of.... eather im computer retatrted or its something really confusing
Comment by Guest, posted on Mar 28, 2009
My iTunes will not read my iPod but I can't reset my iPod because I don't have my music anywhere but my iPod.
Comment by Guest, posted on Mar 27, 2009
my ipod won't sync with itunes. This is after i reset it to the original settings. I am running windows xp. The error message reads that the required disk cannot be found.
Comment by Guest, posted on Mar 21, 2009
Ok, my iPod is plugged into my
computer.
But the "Sync iPod" button is blocked.
HELP ME
Comment by Guest, posted on Mar 16, 2009
I used to sync my music from my play list then restore it and again sync it but all of a suddent did.'t sync no more I was wondering if you can help me
Comment by Guest, posted on Mar 15, 2009
i pod will not sync. file cannot be found. down loaded new i-tunes. still my ipod says connected but cannot access i pod on left hand column.
Comment by Guest, posted on Mar 05, 2009
the ipod "---"'s ipod cannot be synced the required disk cannot be found
Comment by Guest, posted on Feb 21, 2009
Hiya, also have the same problem, i've downloaded songs to itunes, however itunes tells me that it can't detect the ipod...any ideas as i'm loosong my mind !!
Comment by tara_duncan0, posted on Feb 15, 2009
Same problem... what's the fix?
Comment by bayleeonna, posted on Feb 11, 2009
Ok i plugged my ipod in and it popped up cant syncronize unknown error -49 what to i do?
Comment by greekhikers, posted on Jan 30, 2009
Hello I have a Ipod Nano 4gb and although my computer recognizes that it's connected, itunes will not. I have the songs downloaded but I'm unable to tell itunes to update my ipod.
I've been trying to figure this out for 2 days now, if ANYONE can help I'd be extremely grateful!!!
Comment by whlennex, posted on Jan 24, 2009
I have the same issue, what is the fix?
Comment by Guest, posted on Jan 17, 2009
iTune screen turns pink and the List on the left turns dark blue.
Comment by Guest, posted on Jan 08, 2009
i didn't eject i just unplug it, and it said it is corrupted
Comment by Guest, posted on Dec 31, 2008
I have an iPod Touch and it won't sync with iTunes. It wont even show up on My Computer.
Comment by suerowe, posted on Dec 30, 2008
my itunes screen turns pink and my ipod wont sync
Comment by Guest, posted on Dec 19, 2008
im having the same problem
Comment by dhanson92, posted on Dec 12, 2008
where is the solution that worked for misalou? how do i see the solutions?
Comment by Guest, posted on Dec 11, 2008
ipod will not sync with itunes
Comment by ap2v, posted on Dec 11, 2008
my ipod will not sync in fact itunes isnt even picking it up..but it's still charging!?
Comment by vaughanois, posted on Dec 05, 2008
I have a 3rd gen 20Gb ipod and recently it has failed to Sync with ITunes. I ended up restoring it to factory setting which it did ok. It appears as my IPOD on my computer but is now not seen at all by ITunes. All the factory setting are there and it charges fine. Can you suggest what to do please?
Comment by kissmylipss, posted on Nov 28, 2008
my ipod will not sync.
it's like itunes isnt even picking it up..
it still charges perfectly though.
but even if i look under file to sync my ipod maually
it just isnt there.
i wont pick it up.
i really need help.
fast, i miss my ipod
Comment by Guest, posted on Nov 23, 2008
bfx
Comment by heideisland, posted on Nov 07, 2008
I plug in my iPod to iTunes and it does not sync. I hear the notification via the little bell telling me that I have plugged in new hardware but the option to sync the iPod is not active in the file directory. What is wrong?
Comment by jiosorio6, posted on Oct 28, 2008
Comment by lalabambizam, posted on Sep 30, 2008
my ipod wont sync when i connect it to the computer
Comment by dradlover12, posted on Sep 17, 2008
ok mine just wont be read what do i do
Comment by Guest, posted on Sep 17, 2008
my ipod will sync with itunes, as far as play counts, but new songs, and video wont sync with my ipod
Comment by Guest, posted on Sep 12, 2008
i tried to sync my ipod but it keep saying "the ipod "hp ipod can not be sync,the required disk can not be found" and i'm sure i didn't required any disk.
Comment by depre1pj, posted on Sep 08, 2008
I am having an issue with my
Ipod.
It gives me an error code when I plug it in saying that it cannot sync
because the files or directory has become corrupt and unreadable, or do not exist.
I
am good at following step-by-step instructions, but have no clue how to
even access this directory so I can *see* if anything is locked.
Any ideas? Thanks!!
Comment by Guest, posted on Sep 05, 2008
my ipod wont sync
Comment by Guest, posted on Aug 29, 2008
i plugged my Ipod into my computer and went to add songs onto it. when the songs added and i ejected my ipod the whole thing was wiped :|. including my itunes library. now when i plug it in itunes wont recognise it.
Comment by In Aid, posted on Aug 22, 2008
My iPod has been on sync lock for about 3wks now and I have tried everything I can possibly think of. I've tried formatting it and even automatically syncing it but the problem persists.
Anyone got any idea?
Comment by bigobi1809, posted on Aug 18, 2008
Same Problem, but no solution is posted
Comment by rusty138, posted on Aug 17, 2008
My Video 30GB iPod won't sync to Itunes...I updated iTunes,Windows and Microsoft on my PC. All went well but still get "error message -69" when trying to sync iPod.
Comment by NHugsnkisses, posted on Aug 16, 2008
okayy i hav had this problem for like everr
itunes doesnt want to schycronize songs
into my ipod wen i plug it into the computer
the ipod charges but nothing happens the computer
doesnt seem to make a change neither does itunes wat
should i dooo???
Comment by hjocho, posted on Aug 13, 2008
Plugged in to computer to sync and message Do not disconnect stays indefinitely have tries updates and repairing files but no change
Comment by Hollister12, posted on Jul 30, 2008
Ipod 5th Generation Will Not Sync With My Ipod Ive Tried Restoring It And Putting Into disk Mode And Restarting it and Itunes is saying that is it corrupted and try to Disconnect and Reconnect The Ipod I Need Help!!!!!!!!!!!!
Comment by mgcampbell, posted on Jul 04, 2008
I have an ipod nano and when I connect it to sync, my computer recognizes the hardware, but itunes doesn't show the ipod icon and doesn't recognize that the ipod is connected. I've tried everything, even being on the phone with numerous apple people. I have the current verison of itunes, also. Any suggestions?
Comment by Sabra66, posted on Jul 03, 2008
Can't sync ITunes with IPOD mini. authorized computer, tried all and manual and neither works. ITunes says my programs are current.
Comment by kpi1630, posted on Jun 22, 2008
whenever i plug my ipod in the itunes page freezes and when i unplug it an error code shows up. my ipod is music-less and it sucks.
Comment by erinkirby, posted on May 31, 2008
Everytime i try to sync my ipod is says that it does not have the files necessary to sync it.
Comment by jimbo77, posted on May 10, 2008
i installed itunes v 7.6 recently, i then tried to sync my ipod, but, i keep getting an error message saying that my ipod cant be synced as the relavent files are missing! what shall i do. i noticed that someone else had the same prob and they managed to fix it......
Comment by Bryahfire, posted on May 10, 2008
when i plug my ipod nano into my pc it wont sync. It says it cant find the files or something? Ive tried heaps but its not working.Help!
Comment by shnbenedict, posted on Apr 04, 2008
Ipod wont sync w/ itunes?
Comment by Guest, posted on Mar 11, 2008
the screen for syncing doesn't even come up anymore. I've just added a bunch of songs to my library but when I press file and look at the item listed "sync IPOD" it is not highlighted therefore I can't sync. Please help!!
Comment by Guest, posted on Feb 22, 2008
hi my ipod doesn't sync any music. it sometimes doesn't say "do not disconnect when I plug the USB cord in my computer. what do I have to do to get my ipod to work??
Comment by bobbowen, posted on Feb 22, 2008
am having an issue with my Ipod. It gives me an error code when I plug it in saying that it cannot sync because the files or directory has become corrupt and unreadable.
Comment by kelonia, posted on Jan 14, 2008
i have the same problem, what should i do???
