Question about HP PSC 1315 All-In-One InkJet Printer
After changed cartrige, every time I turn on the printer,it always prints the test page.
  • gyang Sep 05, 2007
    Follow the picture on the test page. Put test page on top printer, then press the button of the scan.
I would first contact Stylus website view the troubleshooting remarks. I probable says to uninstall the software dirty disk or 15 other things its a process of elimination like humm? how things could keep a car from starting.
Posted on Sep 01, 2007
SOURCE:
Every time I change the ink cartrige, my printer prints with a shadow behind the letters. How do I fix this?
You need to align the printer by printing a test page.Turn the computer on then open the ink compartment remove and replace. The ink cartridge.Then when prompted to print a test page follow the instructions and it dhoud be fine.
Feb 13, 2011 | HP Officejet 4110 All-In-One InkJet...
Not printing black. Have done 10 test pages, still not printing black, the three other colors are fine. What do i do?
change to a newink cartride on my mfc3360c and test print so many times but no printing black, and the printer is only a month old. need help badly. thanks
Mar 10, 2010 | Brother MFC-3360C All-In-One InkJet...
Just had my color cartridge refilled, and reinstalled correctly. However, the printer will not print with the color cartridge in, but will print with the black cartridge only.
your newly installed cartrige which is the colored one is not detected or mybe damage....may i ask if how many times did you refill already your cartrige?refilling a cartrige can cause damage to its circuit i suggest purchase a new colored cartrige and see if it works.
Oct 09, 2009 | HP DeskJet 845c Printer
Printer making correct noises but paper coming through blank. New cartriges installed but still showing empty.
First do a test print by turning printer off and it should be hold the form feed button down while you turn it back on. If it does a test print page and prints fine then your problem is that your printer driver software needs to be reinstalled if it is not already. Printer driver software can become corrupted over time and get gliches in the program. Let me know. Good luck.
Jan 15, 2009 | Office Equipment & Supplies
HP Business Inkjet 1200 printer always prints the Alignment Page
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | HP Inkjet 1200dn Printer
Test printing
If you've recently changed your cartridges, the printer will try to print a test/alignment page. Note the instructions on the test page indicate what to do to complete the testing/alignment procedure.
1) Let it print.
2) Place the test page upside down on the scan plate.
3) Hit "Scan" and let it finish.
When the machine completes the scanning procedure, you'll be able to switch the printer on and off or reboot your computer without it printing the test page. By Dubbya
Sep 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
No printing
If you brought new Lexmark cartridges please change it as it comes with one year warranty but before try to perform a self test, (i.e make a copy) if it works then try printing , if get the error then change the cart.........................
May 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Does not print
hi you change your cartriges genuien if properly setup your cartriegs
then install your driver & if show your printer then test your print page. not on or off your printer  it is cartriegs problem.
best of luck  jimmmmmmmmmmmm.
Feb 09, 2008 | Canon i80 InkJet Printer
My printer keeps printing the test page every time it's switched on
0.gif Re: HP PSC 1513 all in one by Bert t.gif (9/25/07 1:07 PM) reply + / - http://h10025.www1.hp.com
0.gif Re: Re: HP PSC 1513 all in one test page always pr by Anonymous (12/12/07 6:14 AM) reply + / - Subject : How to disable the test page that always prints when you switch on the HP PSC 1513 all-in-one printer.
Take the test page ( also called : alighnment page ) that always prints when you switch on the printer and place it face down in the scanner.
Then press the scan button on the printer itself.
(this is the button at the bottom of all the buttons on the printer/scanner.)
Make sure that the printer scans the test page.
( sometimes you press the butoon and it doesn't scan )
( it makes a scanning noise when scanning succesfully )
Then it will stop printing the test page ( alignment page ) ever again.
This is a really stupid product feature on HP's part to waste ink and force people to buy more cartriges.
[email protected]
Nov 29, 2007 | Office Equipment & Supplies
Prints test page every time the printer is turned on
This might be an alignment page. To get it to stop, you will have to go through the alignment and new cartrige setup in the hp software. This should be located under Start/All Programs/HP folder. I'm not sure what the software would be called but it should be easy to do if you have the HP software installed. Hope this helps!
Nov 07, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
