Take the top part off and look at it. there should be some screws around the circumference of the top holding the upper part. remove these screws and the motor/switch section should come off. You'll probably find more screws holding everything else together. the switch fits into an all plastic holder and is more than likely a slide switch.
I just did this. There are a lot of screws involved - mostly Phillips. I did run into a couple odd ones - probably there to protect idiots from themselves. One of the odd ones I eventually got, the other I drilled out. The connector on my switch came off, simple fix. I put 'Great Stuff' on the wire to hold it in place so that this did not happen again.
I have a Genie 200ph wet/dry vac. it has a long thin bag inside that catches everything. where can I...
(More)
I have a Genie 200ph wet/dry vac. it has a long thin bag inside that catches everything. where can I get new ones and a manual
