Question about Maytag PAV2300 Top Load Washer
Quit . Will not do anything. I checked the power to the machine.
Started to make a squeeling sound when in the spin cycle, then stopped. when i try to restart it in any thing cycle. the motor starts, then turns off in a few seconds, then i smell something burning. I looked at the pulleys and when i try to start it the motor pulley turns but the other two do not turn. Then it shuts off.
  • 291 Answers
See if you can turn by hand.. the transmission pully and pump pully.. sounds like one of them is bound up, the smell was probly the belt burning with nothing starting to spin
Posted on Sep 01, 2007
3 Suggested Answers
mindreader
  • 578 Answers
SOURCE: The Maytag washer doesn't spin and had a burning
You should have a tensioner pully (a small wheel on a piece of spring steel) that hold the belt tight.
If that spring steel is broken or weak, then you will have to take the broken one to your local appliance repair parts shop and obtain a new one.
That should keep the belt tight and keep the drum spinning.... -Jim
Posted on Oct 23, 2009
  • 389 Answers
SOURCE: Washer tumbler does not spin in final stage
hi sounds like the gearbox has slipped a cog and stuck that will cause the belt to burn
Posted on Nov 02, 2011
Not doing anything, making a ratchetting sound, won't wash, spin,rinse, anything
Have you checked the drum for residue that may actually prevent it to spin? try to check the cycle selector as well and try to load more clothes... keep us posted, thanks for using fixya!!
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
Mav6000awq
well..that would certainly make it sound better. you might want to check the bearings and belts first though..
Mar 10, 2008 | Maytag MAV3855A Top Load Washer
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Engine noise on area of pulleys and sometimes engine tries to sto
Don't know if this helps. Had squeel in belt area. Occasionally engine would stop when squeel got loud and sometimes engine would try to quit while going at various speeds. Found tensioner pulley was bad and changed it. Still squeeled and engine would stop when squeel got loud. This time while sitting in yard. Further checking found binding in power steering pump. Will be putting on new one tomorrow. Hope it works. Will update.
Nov 28, 2008 | 2004 Ford Freestar
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
I have a Roper washing machine that will fill with water, agitate, and stops. I replaced the lid switch assembly and tried it again. Same thing, but one step farther. It went past the agitate and...
The black dust is from the motor coupler. It is normal to have some under the unit. If it stops completly and you chaged the switch check the lid adjustment if the lid is loose it might not make the switch all the time.
Apr 24, 2008 | Washing Machines
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Squeeling noise
It could be just a dry belt and pulley. You could try the old squeeking car fan belt trick and rub soap on the belt. You can even buy sticks of anti-squeek from automobile outlets.
May 10, 2007 | Maytag Performa PAV2200
Maytag PAV2300 Top Load Washer Logo
130 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
