Question about Samsung SGH-D600 Cellular Phone
Won't switch on
When I try to awitch the phone on, the screen lights up briefly and then goes off again. When I plug it in to the charger, the same happens repeatedly - it switches on then off. Any thoughts? all my numbers are on the phone memory.....
Because if it's battery is of japan it can be burst and if it's battery is of india it can't be burst because japan makes duplicate battery and india makes original battery.
Posted on Sep 01, 2007
SOURCE:
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
Phone problem
When you dropped your phone a wire inside of the phone must have snapped and disconnected the phone from the energy switch. I would take it to the company that supports your phone ex. LIME, Digicel Etc. I hope I help
May 20, 2013 | Cell Phones
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I'm trying to recharge my headset but the green light remains on (I clicked on the botton on the headset piece but it won't turn off). When I try to turn it off, it beeps at me
try doing a system reset press the call control button and the volume mute button at the same time for 5 seconds. when the talk indicator light blinks release both buttons. press the call control button again and the talk indicator light will blink again briefly headset is back to normal then unplug the charger from the charging jack for 5 seconds and plug back in headset is reset. if that doesnt work then replace the battery in headset.
May 05, 2011 | Plantronics CS55 Wireless Headset
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Feb 17, 2010 | Indesit W 123 Front Load Washer
Coffee cup on Pantech Breeze screen
Power button needs to be depressed for several seconds to activate.
Aug 28, 2009 | Pantech breEZeTM Cellular Phone
02 xda orbit..
If the light doesnt turn to orange after a few minutes on the charger then the problem hardware related. Try another battery if there is no change then there is fault in the device, and repairs are required.
also you can try
this:
1. Plug it in the Charger without the battery inside.
2. switch on the power.
3. Without removing the charger plug in the battery.
4. Light should turn orange.
5. Wait a moment or two then power it on.
that might get it to work.
May 09, 2008 | O2 Xda IIs Pocket PC
Samsung SGH-D600 Cellular Phone Logo
53 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
