I hear a quiet buzzing, but no spinning at all! Help? I have it disconnected and in my garage right now.
Comments:
Apr 03, 2009
- Here's a little more clarity. Since posting this, I found the model # 110.230321. I replaced the coupler which was broke but in place. Still no results. The agitator started to spin, but when the machine got to the spin cycle, it just filled with water. Drains ok too, but with more noise than usual. Today, I pulled the motor off again and slippled the transmission out. Transmission rotates fine for a little bit of time, then locks up. When I keep trying to rotate the shaft, it ultimately breaks loose and then locks up again. I'm guessing that I have a transmission problem. Shouldn't it rotate freely while holding it in my hands?
Apr 04, 2009
- you nailed it trydisndat! Tranny had a broken piece of metal under the main gear. I got a replacement and put her all back together, but this time,... nothing! Water didn't even dump out and no agitator at all. Dumped all the water and looked underneath, found 1 wire off motor. Reconnected and fired it up, still nothing but a hum during the spin cycle setting. Took the motor off and reconnected the electric lead and the motor spin only in the spin cycle setting, but not the other settings. I this also a motor issue or does the water switch need to sense enough water to start agitation? I'm ready to just buy a new machine!
Apr 05, 2009
- Another adder. I hooked iot up and ran it through the cycles. The only thing that did not happen was the spin cycle. It must be an issue with the tranny. I'll pull that back off tonight and break it open. When I replaced the metal dog leg under the main gear, I must have put it in the wrong position. I did look undere the washer when the spin cycle was called for and did see the coupling spinning, so that's why I'm going with another check of the tranny. Also heard a knockingn noise every second or two when the motor waqs spinning for the spin cycle.
the model number given here yields nothing but it sounds as if your "drive to motor transmission coupling" is broken I need the true model number to help you
yes it shoud rotate freely in hand. Here's a site to go and see all the parts to your washer www.repairclinic.com enter model number and scroll all the way down. Where you see all parts click the red 100 and it will show 100 parts per page. There you can find transmission parts or the whole new unit. Good Luck. And yes you have transmission problems
Comments:
Apr 04, 2009
- agitation won't start until the right amount of water is in the tub
Have kenmore elite #8526056. It agitates at the beginning of cycle while filling with water and doesn't seem to be progressing throught cycle properly. Doesn't spin well either.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 3.2 cu. ft. Super
Kenmore 3.2 cu. ft. Super Capacity Plus Top Load Washer
kenmore catalyst washing machine plugged in but no power is there a fuse inside that might be going...
(More)
kenmore catalyst washing machine plugged in but no power is there a fuse inside that might be going out it comes on and goes back off from time to time
my washer isnt filling when you select anything higher than a meduim size load, it gets to a certain...
(More)
my washer isnt filling when you select anything higher than a meduim size load, it gets to a certain point and wont fill any further, the only way to get it to work is to let it spin out and start again, if i turn off the machine, to soak something...the water drains out completely!
