Question about Dell E173FP 17" LCD Monitor
Monitor blackout thought green powerlights on
Hey ive been reading your forum for solutions but have yet to find one so here it goes. i work at a school repairing computers recently they were plaining to throught away several monitiors that all have a blackscreen (blankscreen) thought the power lights still on these screen have all been tested with many different comps including my brandnew laptop. is their anything i can do to salvage these screens
  • deyoswed Sep 01, 2007
    sry i missed to say that when ive tried the faulty screens on different comp all of witch i know work, excluding any kind grafikcard related problems or comp problems
  • 30 Answers
When your dell e173fp lcd monitor black out, the led power light are still green color. Normally, this will be the inverter board or ccfl lamp problem. May i know, after this monitor black out, do you have try use the torch light to see any display on the screen? (sometime the display are darkness only and not totally no display, you need see it clearly). Any details on repair lcd monitor please goto this website, http://www.fastrepairguide.com
Posted on Sep 10, 2007
SOURCE:
My monitor, hp w2007, shows for about 20 seconds when turned on then goes blurry then black how do i fix???
The most common problem that causes the screen to go to a black screen is due to bad capacitors in the screen's power supply board. The bad caps are the cylindrical and will appear to have bulging tops. 66c561df-0d01-416a-ae23-71f3b3965c88.jpg
Oct 24, 2010 | HP W2007 LCD Monitor
The power button flashes between blue and yellow. The monitor screen stays black. I have the exact same monitor and switched it on to my other computer, and the computers are both working fine.
perrycdoq, Did you do flashlight test? Is your monitor also "blank"? Did you visit this old net blog? http:///www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading there then come back and tell me if you think same thing might be wrong with your unit. Will you do the troubleshooting or contract out the work to qualified electronics technician to fix units "switch-mode-power-supply / inverter ballast circuit? 12fixlouie
Oct 03, 2010 | HP w1907 LCD Monitor
My hp w17e will only work for about 5-7 seconds when I first turn it on, and then goes blank. If I turn it off and back on again, the same thing happens. Is it fixable?
You should do some research here first: www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ It's an old blog, but could offer a solution worth exploring. Just remember to rate this response after you do your research there. 12fixlouie
Sep 25, 2010 | HP w17e Monitor
Monitor will come on, monitor status box will come on and then screen goes blank. How can I fix this?
rwhite97, If your pc is working fine with substitute monitor, and w1907 lcd unit does same (black screen, or blanknblack screen) when connected to a "known good" pc, then you should visit and read some stuff at this 2005 blog. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Then learn the flashlight test and what it means. Then go to YOUTUBE for video clips on lcd monitor disassembly and lcd monitor repair if you are into do-it-yourself repair. Remember this!!! Your w1907 unit uses the same basic design and operation principles that ALL brands of ccfl back-lit lcd monitors use. Good luck with the repair. Come back here and leave comment after doing your research/investigation and then rate this response. 12fixlouie
Jul 16, 2010 | HP w1907 LCD Monitor
Screen goes black and when tuned off for a while will come back on and sometimes flickers like it has a bad connection. It is a hp pavilion f 1703
bmiller013, Problem been around for some time!!! Surf over to this blog and do some reading first. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Then you can come back to this posting and rate it if it helped you find out why your monitor has crapped out on you. Good luck with the repair guy. 12fixlouie
Mar 11, 2010 | HP Pavilion F1703 17" LCD Monitor
ViewSonic VA912b monitor fading out during boot
It is probably the power supply, or the inverters.
Similar problem with solution, though it requires you to know something about electronics.
http://www.badcaps.net/forum/showthread.php?t=6876&highlight=*va912*
Jun 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Monitor Blackout
Here is a website that provides instructions to repair the inverter on a similar model:
http://josepino.com/?howto-repair-dell
Feb 23, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Acer al1714
The problem may not be the monitor. Acer AL1714 is known for its weak power supply unit. Unplug power supply from monitor. If the green light on monitor comes on but goes out quickly, the power supply is the culprit!
Dec 28, 2007 | Acer AL1714 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
406 people viewed this question
Ekse
Clive
Clive
