NAD 5340 CD player 1988. No Display
This CD player's audio is fully functional and sounds great. However, there is a small function-display on the front that tells you which track you are playing. It does not light up. I have an oscilloscope, a good digital meter, a small analogue meter, and experience repairing various electronics, however, I have no schematic diagram for this unit. Can someone supply a schematic or a service manual? Or does anyone know if this is a known common fault? So far, I've eyeballed the electronics, and there are no signs of burns, popped caps or loose connections. I haven't placed a measurement yet. The display driver chip is NEC D75P308GF and written on the board is TK-T134 94V-O I can't find a spec sheet for this chip. If someone finds a description of the pinouts it would help. Thanks!
  • IamSpOOk Sep 22, 2007
    Fixed it. Pull off the front panel. Undo the screws, careful not to let the buttons fall out. unsolder all of the display leads and pull the display away to reveal a cowl with a red filter. Slide the cowl to one side and pull it away to reveal two small light bulbs. Replace each light bulb with a pc-mount bright white LED in series with a 1/4 watt 150 ohm resistor. Negative 5v is in the middle of the board. Mount the resistor vertically and leave some slack in the leads. Then sand off the shiny surface of the LED to make the light diffract a little. Put a layer of grease-proof paper inside the cowl to spread the light a little more. Test the LEDs and reassemble the display by soldering the leads back in. Examine solder joints under a magnifying glass to check for shorts and dry joints. Scrape away solder flux, clean with toothbrush and isopropyl alcohol. Test and reassemble.
  • 42 Answers
SOURCE: Laser unit NAD 5100 Monitor Series
Hey, I think you can bye new laser here http://www.pltv.org.uk/laser.htm I have a nad 5300 monitor series, same laser as 5100, you can buy the hole cd player from http://www.miguelovitch.dk Laser work, but problems with cd transport. When i 'help' the cd transport, cd play as expected. And i agree, it is a nice cd player, also i have heard lot of nad cds on quad 405, sounds realy good. Try to visit my site, i also have a lot of free schematic for nad, denon, quad and mora. Also repair notes for amplifiers, tech videos, diy schematics and more.. Also at this moment i am working on a new 'nad cd service movie) including cleaning, maintenance, repair and more on nad 522, 501, 502 c521 and more see you best regards michael miguelovitch http://www.miguelovitch.dk
Posted on Sep 27, 2007
  • 42 Answers
SOURCE: NAD 502 CD player LCD problem
hey, well, typical problem i nad cd players, and also receivers by the way. The proble are tha nad use standard glow lamps. And as we know, the blow!! And often when you move around with the cd. Well i do have repair note for this one also. http://www.miguelovitch.dk/ go to the menu: 'amplifier repair notes' (yes includes cd players ;) ) Here you can find free amplifier repair notes, an go fore nad 705 repair fix (same fault with defect bulb's as in you nad cd) And also a technical repair movie showing you the hole process of the 'workaround' this fault i NAD 522 (NAD 501, 502, 512 and more) http://freemovies.s-educator.org/repair_movies/nad/nad_cdplayers_defect_lamp_in_display_stremingvideo.html best regards michael miguelovitch
robotek
  • 1512 Answers
SOURCE: NAD 5425 CD Player display light out
Hi aartman
Yes it does have backlamps.
They are soldered to the PCB so you will need a few tools like a soldering iron, philips screwdrivers, solder, and some replacement lamps. Replace the lamps with this type from Farnell electronics. They have a 15000 hr life expectancy and last alot longer in the unit. I have tried many types of lamps over the years, and found these are the best choice if you want them to last.
FOR YOUR SAFETY-BE SURE TO DISCONNECT FROM THE MAINS BEFORE REMOVING THE LID
To get access to the lamps, you need to pull the main PCB out of the chassis to then get access to the bottom side of the printed circuit board where the 2 screws that retain the white lamp reflector assembly. Change both lamps with the type I mentioned,
6ab9edb.jpg Be careful not to flex the LCD display that is now exposed, it is quite fragile with the support of the lamp reflector cover no longer in place. ... reverse procedure to reassemble and away you go.
I am more than happy to talk about this solution with you further. Just ask away. Cheers
regards
robotek
Posted on Dec 12, 2008
SOURCE: Hannspree HF259H Audio (sound) Problem
I connected an audio cable from my sound card to the audio unput on the monitor and the monitor plays everything as well as my other speakers connected to my sound card. I have a Diamond multimedia sound card (7.1 setting) By the way, the monitor speakers sound "tinny" if the volume setting on the monitor is too high.
Posted on Jan 23, 2009
SOURCE: NAD C541i CD Player won't turn on
I recently bought a second hand C541i as is and I had the same thing; no power up. I took it to a service centre, they re-soldered the connecting pins for the transformer socket. It now works well.
After that I realised that it could have been the problem with the Burson Audio clock that was installed buy the previous owner but had intermittent playback problems. A study of the schematic revealed that the +12v rail for the clock, is from a different secondary coil winding than the +5v for the DAC etc. And the -12v for the analogue output stage could be from a different pin on the connector as well.
I hope this helps.
Posted on Mar 03, 2009
NAD C521 on / off button light
"POWER ON: Press this Green button to switch on the power to the disc player from Standby mode. The LED will change from Amber to Green, and the EFL display will illuminate."
So besides the L.E.D. the unit has another visual indicator that it's turned ON, the display lights up. Is this worth pursuing a fix?
Mar 03, 2010 | NAD C521 CD Player
I have a NAD 510 CD player with no display lighting working and would like to repair this myself, and also a NAD 710 receiver/amp that does not tune in any stations but otherwise works fine, would it do...
wont do any harm to open it up. look for blown fuses. i have a NAD amp and the desplay goes blank and sound distorts when there is a blown fuse inside, my amp has abourt 8 fuses inside it 4 per chanel
Jan 04, 2010 | NAD C521 CD Player
NAD 5340 spins disk but no audio output
Hi...
I've worked on a number of NAD players.
2 things to look for.
1. The belt that pulls the drawer in also lifts the laser assby to the disc. Those wear out.
2. The capacitors in the power supply section tend to age poorly.
Theyre usually 470 to 1000 uF(microfarads)
Also try pulling all the cables and re-seating them
If any of this works, rate my help please,
Thanks
May 07, 2009 | NAD Audio Players & Recorders
NAD 5355 loader not functioning due to stripped gear
Hi ...
Contact NAD parts thru their website.
or
oaktreent.com might have spare parts.
Mar 12, 2009 | NAD C521 CD Player
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
No display but fully functional regarding sound
More then likely the flex cable that connects main p.c.b to the connector keyboard plugs into is defective. For service manual email kstahl65@att.net
Jan 30, 2008 | Pioneer DEH-P6800MP CD Player
High pitch sound even with speakers disconnected
1.the problem with your audio processing circuits and improper power filter
2. Check audio amplifier coupling capacitors
3. Rectifier capacitors
4. contact service centre
Oct 26, 2007 | NAD L40 CD Player
NAD 402 Tuner problem
It's sounds like a chip gave up the ghost. You may want to try
turning in on and off a few times to see if you can get the culprit
to function properly again. Electronics are strange creatures in that you can at times just shake them and they will begin to function properly again. A loose wire here or there, instead of any real problem.
However, if the problem's more serious, given the cost of servicing these products, you may be better off just going to Ebay and buying a used one.
I recently purchased a nice used NAD 402 with original box
for $58. Upon arrival I found that the backlight to the digital display was not functioning, however the display itself was, and the sound of the tuner is amazing. It is nearly the equal of many tuners which I have owned in the past at as much as 50 times the price.
Best of luck to you...
Sep 06, 2007 | NAD Audio Players & Recorders
Eclipse 5340 deck
I forget about the security light but I do know about the clock. I believe you turn the deck off and hold display or push display and the clock will come up. Then use the preset buttons for adjustment. I think 1/2 is for the hour and 3/4 are for the minute. It has been a while for me doing this but I think it is right. I just powered mine back up a while back and am trying to find my starting cd. You wouldn't happen to know how to reset this function and start over?
Apr 11, 2007 | Eclipse 5340
No sound
Bad regulators in the power supply or the capacitors in the power supply are drying up. Needs to be taken into a shope as there are no user serviceable parts inside these units good Luck
Aug 05, 2006 | NAD 712
1,023 people viewed this question
 Grubhead
Grubhead
