Question about HP PSC 1315 All-In-One InkJet Printer
PRINTING BLANK SHEETS
Hi, everytime i try to print something the paper either comes out blank or most of it is missing.its not the ink because ive bought new cartridges twice!! and ive run the test pages and they come out fine its just everything else that wont print. can anyone help
  • Katie25 Apr 15, 2008
    I have the same problem, sometimes my printer will print fine, sometimes it looks like it is running out of ink (it isn't, I've replaced both cartridges), sometimes it sounds like it's printing the whole page, but the page is blank. I cleaned the cartridge heads, I aligned the heads, I un-installed the drivers and re-installed them from the HP website and I've run the test/allignment page through a couple of times.
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Posted on Sep 01, 2007
Canon PIXMA MX300 Office All-In-One Printer and Fax MX 300 printing blank sheets
Do you have ink in the cartridges? Just because the computer says there is ink does not mean there really is ink.
Try making a copy and see if it copies. That will tell you if you have ink. Just go to the canon all in one and place something on it to copy and press copy from the controls panel on the printer.
May 31, 2012 | Office Equipment & Supplies
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 01, 2012 | Dell A920 InkJet Printer
Ive a kodak printer esp 7250 i have used it a couple times to print off my photos and its been fine,i got the printer out today and put new ink in ready to photo copy and it is not printing for some reason...
How long was the printer stored before you took it out to use it? You can't store a printer with or without ink cartridges in it. When a printer sits, the ink that is in the print heads settles and dries. Once that happens, the print heads are pretty much ruined. You can buy new print heads, but its usually cheaper to buy another printer instead. The reason it is not printing is probably because the print heads are plugged.
May 12, 2011 | Kodak Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Printing Blank Sheets
This is a common problem with printers. Reinstall the driver, preferably from the Canon download website. It will have the newest drivers and have fixes for any problems which existed before. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
May 09, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Printing out blank sheets of paper! Don't know
Sounds like there is something wrong with the mainboard of the computer... Did you try plugging it into a different computer, uninstalling and re installing the driver again. If after all that is done and the same problem still is happening I can see that the printer could be non working anymore and is just freaking out. Try contacting Brother and see what they can do for you.
Good luck and sorry for your luck
Aug 12, 2009 | Brother Office Equipment & Supplies
FMC240 PRINTER NOT PRINTING
1-remove printer driver from the computer.
2-reinstall printer driver to the computer and update it through net.
Feb 20, 2008 | Office Equipment & Supplies
HP PSC 1315 All-In-One InkJet Printer Logo
305 people viewed this question
Clive
Clive
