Question about Car Audio & Video
PORTABLE DVD SYSTEM BY LUXMA, PLAYER WON'T START UP
LUXMA CAR DVD PLAYER ITEM #LDVD-108TV WON'T POWER UP. THIS JUST HAPPENED. WHAT CAN I DO TO TROUBLESHOOT MYSELF, IF ANYTHING?
SOURCE:
silly girl
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
  • 944 Answers
SOURCE: Portable Car dvd player
Here is the link to the owner's manual and the installation manual for your player; http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070347_38318,00.html You have to register to access the info, but it is free. The player runs from the car battery power source, so it can be run from a transformer in your home - available from any good hardware store. The player itself specifies a power source of 14.4 voltsDC preferred, 10.8 - 15.1vDC is allowable. maximum current drawn is 10Amps. If you take these specifications to a hardware store they will be able point you in the right direction. a car battery charger could do the job, but i would recommend putting it through a battery not directly to the player as this will possibly damage it. make sure you put a fuse in the system near the player i would recommend a 5A fuse, if that blows too much then try a 6 or 8 A fuse - dont go over 10 amps and make sure it is a quick blowing type. If you have a charging car battery in your home, be very careful to ensure there is proper ventilation - when charging, the battery gives off hydrogen gas which disperses without problem from a car engine bay, but can build up to explosive concentrations in a building without adequate airflow. Some batteries have a small connector for a breather tube, which can be led outside through a window or a hole drilled in the wall. other batteries need to be boxed, and a breather tube put on the box. If you are careful about the hydrogen gas then this can be quite safe - make sure you keep the battery well maintained - follow the safety instructions about dealing with acid, insulate the battery terminals properly to avoid shock, sparks or power surges. Box the battery in a vented box - make the lining acid resistant (polyester or epoxy resin for instance) if possible. Simpler may be to charge the battery elsewhere and connect it alone to the player - you will have to move the battery around a lot which is inherently a bad idea in many ways. still make sure it is fused regardless. Easiest would be a proper mains transformer/rectifier as described. there is no other reason why you would not be able to use this player at home. Hope this helps, please ask again if you need more info :)
Posted on Apr 14, 2007
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
Posted on May 12, 2008
SOURCE: Coby DVD Player wont play
try running an optical disk cleaner it worked for me but I have to clean often.........a cheap fix if it works.
Posted on Jan 26, 2009
  • 320 Answers
SOURCE: I have sound but no picture on my portable DVD player.
yes it can be fixed.replace the capacitor c564 and c513 on the main circuit board to bring the picture back as this capacitors gets over heated and cause this problem.
Posted on Mar 06, 2009
I have a sony DVP-FX74 portable dvd player that won't turn on. I have charged the battery. Any ideas?
the power system has been interfered with,i won't use a complicated language but i need you to try and use an adapter,if it doesn't work it means the transformer has a problem or it has failed completely and it needs replacement
Oct 25, 2012 | Sony Dvp-Fx740dtb Portable Dvd Player Sony
I need an in car charger for a portable dvd player please
If you cant get a dc to dc plug for your DVD player. Try an AC to DC inverter. Here is one from newegg for twenty five bucks! Hope this helps. :}
http://www.newegg.com/Product/Product.aspx?Item=N82E16882739019
Jan 31, 2008 | Durabrand PDV-705 Portable DVD Player
My DRC6309 RCA portable DVD player will not play disc. It says "loading" and then says "no disc". I have tried different outlets and different discs. Any suggestions? Is there a...
Hello
Either your DVD players Laser Pickup Unit is dirty or defective or its 'sled' motor has damaged. Sled motor is one, which spins the disc inside. if it does not spins, the main system IC won't get any signal that the disc is "IN", and will show the messege "No Disc". The same will happen if the laser pickup unit is defective or dirty. Insert a Head Cleaning Disc into the system, and play it for atleast 3 times. If there is any dirt or dust, this will solve your DVD's problem. If not, it should be serviced by any skilled technician. It is not a user reparable item, as you have to take out its loading mechanism completly out of it for repair. OK.
Jun 02, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
WHERE CAN i PURCHASE A POWER ADAPTER
Hello
You haven't specified nothing about the model number or any other items of your portable DVD player. Normally all portable DVD player adapters will have a 9.3VDC 2.5Amps adapter to use with. You jsut go with your DVD player to any elelctronic spare parts shops in your town. They can detect the excat voltage and choose the right adapter for you. OK.
May 19, 2011 | Craig 400020017109 Portable DVD Player
I have a LDVD-880TV I WANTED TO KNOW WHAT VEHICLE THAT THESE R INSTALLED IN AND WHAT WAS THE PRICE OF THIS PRODUCT IF U CAN TELL ME NEW PLEASE THANK YOU FOR YOUR COOPERATION ...
Here is all of the information on this product. To find out what vehicle it is in would be difficult. I would guess a minivan or something like that.
http://www.luxmt.com/pages/ldvd880tv.asp
May 04, 2011 | Lux Mobil Technology LDVD-880TV Car DVD...
Suddenly, despite using the power cord, we get a "battery low" message and soon the player stops working. We've been using the DVD player for some time with no issues and this just started...
it is possible that the battery has been reset at a low level so it won't hold the charge. You may need to have it emptyed and then recharge it for the max time or you need to replace the battery.
Mar 17, 2011 | RCA DRC6331 Portable DVD Player
Need new car charger for the LMD model for my true tech portable DVD player
What about a small, light power inverter, that plugs into your cigarette lighter in your car, and has 100 Watts available?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3970959&CatId=237
(Your laptop won't EVEN use 100 Watts! Look at the Ac adapter. (Charger)
Read the specifications on it.)
Aug 07, 2009 | TruTech PVS12701 Portable DVD Player
Need accessories for portable dvd player...
I was tol Funi makes the Durabrand for WalMart, Try this addy http://www.funai-corp.com/support/contact.asp Good Luck
Mar 19, 2007 | Durabrand PVS1966 Portable DVD Player
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
