Phillips Home Theatre System
Model Number HTS3548W/98 Having problems with Region keep comming up on Hired DVD`s and my own personal DVDS. Cannot play any at all. Wrong Region keeps comming up. I have played DVDS before without an issue, now the unit is giving me grief. Any suggestions on how to fix problem. Unit is only 1 month old.
  • Anonymous Aug 17, 2008
    need to decode my dvd player
  • ppayne88 Nov 03, 2008
    I have the same problem, I just bought a new dvd and its saying wrong region. I have tried entering the numbers listed but it isn't working..Nothing is coming up on the screen and nothing is changing...The screen and dvd player still says wrong region....What do I do now?
Once you have connected your dvd player to your tv and the tv is turned on. Turn on the machine and press "disc" on the remote control. Open/Eject the disc tray. Press STOP on the remote control. Enter the following numbers slowly on the remote control " 7,3,4,4,6,6,0". Configuration will appear on the bottom left hand side of the TV for three seconds. Press "PLAY" to close the tray. The DVD player eill return to normal operation. This SHOULD make the player Region free.
Posted on Sep 04, 2007
Cool
Posted on Mar 15, 2008
2 Suggested Answers
SOURCE:
SOURCE: Phillips Home Theatre System
The above solution helped me fix the region lock issue with my Phillips FWD185/94 Hi-Fi player.
Posted on Jul 03, 2008
I have an LG Home Theater Model HB806. It will play only DVDs for Region 4 (Australia and Pacific). Do you know the code sequence to unlock that restriction and play all Regions?
Your home theatre, because it's a BR player, has been made specifically for that region - the region for both the DVD and the BR is hard coded in the processor chip. Because of that there is no other region to switch to so you would need to replace the processor to change the region without making it region free.
Sorry, there is no way of making it region free.
Jun 07, 2011 | LG Televison & Video
NEED TV CODES FOR PHILIPS TV. I HAVE A ONE FOR ALL MODEL URC-5741B00 REMOTE. NEED CODES FOR A PHILLIPS TV.
Here are the codes for your philips tv:
  • PHILIPS Codes: 003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
  • Apr 15, 2011 | One For All URC-3021 Remote Control
    I GOT YOUR HELP PREVIOUSLY. RECENTLY I AM HAVING FOLLOWING PROBLEMS WITH MY PHILLIPS HOME THEATRE MODEL-HTS-3265. **** I HAVE BOUGHT ONE VIDEO CD OF VIOLIN BROTHERS LIVE CONCERT FROM ASHA AUDIO BUT...
    It's possible that this DVD is not from the same region as the DVD player.
    For instance, a DVD from India (region 5) will not play in a DVD player from the US (region 1).
    You may want to check into that and post a reply here.
    Mar 01, 2011 | Philips HTS-3565 Theater System
    I have a Samsung HT BD2 region 4, I go many region 1, they wont play, how can I make it play?
    To unlock the DVD code its defends upon what region you belongs or from were you bought the DVD unit. Just click this site to hack the region code ; http://www.videohelp.com/dvdhacks
    To keep it simple, this means that DVD players and DVDs are labeled for operation on within a specific geographical region in the world. For example, the U.S. is in region 1. This means that all DVD players sold in the U.S. are made to region 1 specifications. As a result, region 1 players can only play region 1 discs. That's right, the DVDs themselves are encoded for a specific region. On the back of each DVD package, you will a find a region number (1 thru 6).
    The geographical regions are as follows:
    REGION 1 -- USA, Canada
    REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
    REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
    REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
    REGION 5 -- Eastern Europe, Russia, India, Africa
    REGION 6 -- China
    REGION 7 -- Reserved for Unspecified Special Use
    REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
    REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
    The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs
    Hope it may help you;
    Regards;
    VOTIT
    Jun 08, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
    Decode region on dvd player
    Try 7385652500070000+INFO When You Put In A Movie Let Me Know If It Works.
    Jan 19, 2009 | RCA RTD255 DVD Home Theatre System System
    ''WRONG REGION'' MESSAGE ON PHILIPS HOME THEATRE SYSTEM
    Ensure both TV & player are on , no disc in player
    on the remote press: disc menu, then open/close then stop
    enter the following numbers:
    7,3,4,4,6,6,0
    you should see region 0 in the bottom left hand corner
    the player should now play, if not and your in Australia ring Philips on
    1300 363 391
    good luck
    Terry
    Jan 11, 2009 | Philips HTS-6500/37 System
    Dvd player is in region 3 need multi region for model philips hts3548w/98
    1.open tray with empty CD
    2. press stop for 2 seconds
    3. press 734466
    4. on the screen region will appear press 0 for all regions
    5. press ok to close then after open and insert your DVD.
    Jul 15, 2008 | Sony DAV-SA30 System
    to play discs from different regions on HTS3548:
    Before you begin, ensure you have connected your DVD player to your TV and both have the power on. Once you have connected the TV, follow the instructions below.
    -- Open the disc tray
    -- On the remote control, press in sequence:
    Disc Menu
    Stop
    7 3 4 4 6 6 0
    OK
    -- Make sure Region 0 is showing on the TV.
    This should hopefully help!!!!
    Jan 02, 2008 | Sony DAV-SA30 System
    768 people viewed this question
     Grubhead
    Grubhead
    Marvin
    Marvin
