Question about ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard
How to repair my system
My is not working if i on my system his display is not working if it work after few second he hang otherwise restart automaticaly, if i restart the system same proccssing again dispaly not working system cpu is working only
  • nattu Sep 01, 2007
    beacuse i am working in my system some urgent working are pending in my systme so that i ask you for plz give me reapiring tips
Try to clean Video Card bronse metal plate same also in memory card bronse metal plate by rubbing its metal plate of eraser..and try to reset cmosby removing cmos battery and shorted it directly by any metal thing..
Posted on Sep 06, 2007
    Novelist:
  • 231 Answers
Hi, the first thing to try is to make sure your craphics card has not worked loose. If this is still firmly in place then try a replacement card. When your system boots and hangs up it is usualy either RAM chips loose or failed and as you say the system boots ok then it will almost certainly be the craphics card at fault. Regards mistyman
Posted on Sep 02, 2007
SOURCE:
I have vesrto 220 tower pc when i play the games & work on word after few mints pc hang and display out & restart the pc tell me what i do?
go to run
type cmd
type chkdsk in black window
it will show if your hard drive is having problem.
it will also show you how to fix the problem it is doesn't work try replacing your ram and then motherboard.
Apr 22, 2014 | Dell Computers & Internet
MY SYSTEM IS HANG & AUTOMATIC SHUTDOWN IN A FEW SECOND
Please check your cpu fan properly connected and working or SMPS fan.
Jan 21, 2014 | Intel Computers & Internet
HP B8850 photo printer originally installed on an XP machine. Now running on a Win 7 unit (SP1) x64. Most printing done from Photoshop CS2. Up until a few months ago, everything ran fine on the x64 Win 7...
Try this.
Right click on the desktop and create a new Text Document, rename it spooler.bat
Be sure your computer is set to display file extensions otherwise you will end up with a file called spooler.bat.txt but the .txt will not be displayed. Right click on the file and select edit. type the following:
net stop spooler
net start spooler
Save the file.
Between print jobs, run this by right clicking on the file and Run as Administrator. Maybe restarting the spooler will work and you will not have to reboot.
Mar 07, 2017 | HP Photosmart Pro B8850 Printer
Most of the time while I'm switching on it, power led does glow, HDD Led glows once and also can here the spinning sound of Processor fan but there is no display and after few seconds it will restart. if...
two solutions:
1- use a cooling hardware. maybe your laptop hangs because of high Temprature.
2- VGA of your laptop almost destroyed !!(sorry damaged).
so you can only take your laptop to a guarantee center.
Jan 10, 2011 | Compaq Presario F572US Notebook PC
The I phone has hanged and the system is locked
Hold the power button and home button for 10 seconds, then press the power button for 3 seconds.
it will restart
Nov 13, 2009 | Apple iPhone Smartphone
Hanging problem
D845GBV no display in skrin.bib tone continuously for 03 times nonstop, after which nothing happens except for cpu fan running.
Sep 03, 2008 | Intel D845GVSR Motherboard
Motherboard_prob
just check is the processor fan is running or not then try with new ram,power supply,
Jul 21, 2008 | ASUS Computers & Internet
Pc is not working
as computer starts hold down F8 and youll see a safe mode. use the safe mode and it might just come back, restart it....sometimes strange viruses does this but i dought in your case.it should come up in safe mode allowing you to save your files ...folders to cd record disks...then you can format and reinstall all programs.
Sep 01, 2007 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Blank screen when moving windows
First, check out this link -- http://www.pcguide.com/vb/showthread.php?t=25482 That board is known for bad caps, the link will show you what to look for.
Jan 06, 2007 | PNY Technologies GeForce 6200 256MB AGP...
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
