Question about Hotpoint Ultima WF860 Front Load Washer
Wf860p computer control automatic
This machine worked fine up till one morning when switched on the display shows normal until you press start when it goes into test mode, does a short test run, then ends with the "on" message, there are no visible signs of any electrical damage on the module, motor reads ok on test meter, and heater element reads ok, so does inlet valves & interlock. there are no fault numbers showing. I welcome any other fault number remedies for future reference, many thanks
  • Anonymous Sep 03, 2007
    i have tried disconnecting the power, no avail, i am an ex engineer of almost 20 years, but this problem is new to me, it is my machine and is out of guarantee, obviously, i have tested the various parts for faults but do not have the hardware key, the machine runs through a quick test procedure then bleeps and allows user to reset programme details, number spin and options etc, then when press start goes into test again, is there an actual faulty part on the board, i am capable of replacing such as resistors and the like, i have also been reminded the power went off the day before, could a power surge have blown something?
I have had this problem it is caused by accidentally pressing both the on and start button together. It puts the machine into demo mode. You need to press both the buttons together again for about 30 seconds. If it doesn't work first time switch the machine off and do it again. Sometimes you have to do this many times before it works but eventually it does work.
Very frustrating.
I found the cause was either leaning on the front of the machine or resting a broom which when you pick it up accidentally presses the two buttons.
Posted on Nov 22, 2007
Its simple its not a faulty pcb you need to take the machine out of test mode and get doff setting
Posted on Sep 11, 2007
  • 183 Answers
This problem is caused by a faulty main PCB, in the back on the left of drum looking from the back, this function should normally only operate when we fit a hardware key in the rear slot provided.you may resolve by disconnecting from power supply for fifteeen minutes and then re connecting but no promises. Regards Advisor
Posted on Sep 01, 2007
  • Tony Coultrip Sep 08, 2007
    I work on these products daily, it is a faulty main PCB.
SOURCE:
Used it yesterday, fine today. Pushed power, fine. Pushed start, why nothing?
Hello. I will take you through some basic troubleshooting. Being plugged in, display working, choices made, does the machine do anything after the start button is pressed? Examples include locking the lid, starting to fill with water, etc. Did you notice any error codes that popped up in the display? If nothing is happening after pressing start, and there aren't any error codes that have been displayed, the problem could be with the control panel. First, unplug the machine for about 5 minutes to reset the main board, then plug it back in. (You might see a spark and hear a "pop" at the outlet due to the amount of current being immediately used by the machine at idle--this is alarmingly normal!) The machine should give a short beep after being plugged in--this tells you that the main board is alive and receiving power. Try to initiate a cycle again. The circuit board for the control panel might be defective if you get the same results. Important: have you had a power outage recently--such as 3-4 weeks prior? They are NOTORIOUS for damaging boards in the electronic washers.
Part numbers:
8564291--USER INTERFACE BOARD
W10104830--MAIN CONTROL BOARD
Link to pictures of the user interface board
8564291 Google Search
Link to pictures of the main control board
W10104830 Google Search
To initiate automatic diagnostic mode, follow this procedure:
press and hold the spin button for 3 seconds, release it for 3 seconds--3 times(yes, do the 1-one thousand, 2-one thousand, 3- one thousand out loud, lol--I do!) All the lights will light up and you will see "88" on the display. If there are any stored error codes, the most recent one will be displayed--Fxx(example: F2--means there is a stuck button on the user interface board) The machine stores the last 4 error codes--keep momentarily pressing the spin button to see any stored codes until the machine displays a C0. Image 3 has the instructions. The first 2 pix show the sequence of the automatic self test and what will be in the display as each of the machine functions is initiated. See the attached pix below. For any displayed error codes, you can do web searches using your model number and the error code to find out what the meaning is. Let me know what you find--to exit the diagnostic mode, simply press the power button. I hope this helps you!
Nov 06, 2015 | Whirlpool WTW6400SW Cabrio Washer
Switch on it shows "test" and cannot programme
It depends on what date the machine was manufactured. The date should be on the plate which is probably in an awkward position on the back ;-0(
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
John C
Mar 22, 2011 | Hotpoint Aquarius WD640 Front Load...
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Automatic brewing
Here is a link to the manual:
http://useandcares.hamiltonbeach.com/files/840156002.pdf
Hold PROG until clock flashes. Continue holding PROG button;
press H and M until the desired
brewing start time is reached.
Press PROG momentarily to
activate automatic brewing.
Mar 25, 2009 | Hamilton Beach BrewStation 47665
It is all black, as if off
when starting windows press f8 key before the windows logo shows up > go to safe mode > click start>control panel> display>adapter>list all modes> choose 800x600 x 16 colours > apply > close > reboot to normal xp. OR When f8 key pressed > choose VGA mode. If this does not work then change the VGA Cable (borrow from someone if its TFT to test)
Jan 05, 2009 | Acer AL1717 17" LCD Monitor
Braun Coffeemaker Programming
to prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Dec 08, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Error Message
I called the Hotpoint helpline and the solution to this problem was simple:
I had to press and hold the start/cancel button until all the lights on the display flashed
then I had to press and hold the start/cancel button along with the on/off button together at the same time, until the word "dOFF" was displayed... the msachine then functioned as normal.
Easy when you know how!
Aug 30, 2008 | Washing Machines
Amana Temp Controls Stop Working - Show Dash - Food Spoiled
could be a glitch in the defrost cycle the adaptive defrost control could be faulty and when you unplugged it you might have reset it it should be ok till monday but i would just get the basics untill the tech looks at it
Jan 26, 2008 | Amana AFD2535DES French Door Refrigerator
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Hotpoint Ultima WF860 Front Load Washer Logo
208 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
