Question about Navman iCN 520 GPS Receiver
Mcx connector my mcx antenna connector has broken off and lodged in the icn 520 female socket.. any ideas how to remove??????
  • thomo Sep 01, 2007
    thanks will try that
    dave
  • 12,061 Answers
Well I have done it with my magnifying glass dentists pick & my fine nosed wire cutting tweaser, and time... But more often it is easier to Disassemble the units & simply unsolder the Female Socket from the Board and replace with a new one, then ya can buy the connectors as a pair.. ensuring proper fit.
Posted on Sep 01, 2007
On my Caloric gas stove Model RSK 3700 UWW, a control knob has broken off leaving about half of its stem (or tongue) tightly lodged in the stove's female control- knob socket. How can I extract this broken...
Unfortunately you can't remove or replace these buttons, no parts seem to be available anymore. Keep a match stick handy to stick in the hole and press the leftover bit.
May 09, 2010 | Jenn-Air JGR8855BDS Gas Kitchen Range
The f-connector of my sharp aquos 46 tv is broken, how to fix it
This is not too hard of a fix, you must unsolder the Old one and resolder the new, you can get the Female Jack, from say Radio Shack, or any good TV, TV antenna store.Remove the back of set with it unplugged and locate socket, unsolder and then replace with new one and solder back on.
Mar 06, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
May 11, 2008 | Navman iCN 520 GPS Receiver
Kenwood micro hifi model rxd-m33v ariel output
You need a 75 Ohm standard aerial connector to 75 Ohm miniature RF connector adapter to fit the socket..
Jan 18, 2018 | Kenwood Audio Players & Recorders
Navman icn 520
There are two possibilities:
1) it is a software problem, in this case you can solve it downloading and installing a firmware update. You can download latest software from here.
This is most likely situation.
2) If the above did not work it means that you have an hardware problem, probably the touchscreen is slightly faulty, or the lcd ribbon cable is not well connected. In this case I suggest to take the navman to service.
Regards
Mar 29, 2008 | Navman iCN 520 GPS Receiver
ICN 500
tall buildings in the cbd reflect satalite signals causing incorect fixes. an ext antenna helps a little bit.
Mar 13, 2008 | Navman iCN 520 GPS Receiver
Navman iCN 520
The CD is not available for download from Navman it seems, but you can get it at thepiratebay.com. Just search for 'navman icn' and you'll find what you need, I just did. Better learn how to download torrents though! :)
Feb 14, 2008 | Navman iCN 520 GPS Receiver
Navman iCN 520N disassembly
press the top and bottom theres clips on the top and bottom
Dec 29, 2007 | Navman iCN 520 GPS Receiver
GPS Antenna
hi
the 8400 does list an antenna accessory but no socket type
there is also a speaker/headphone out socket
are u sure you are not confused
mmcx and larger mcx are common types
http://en.wikipedia.org/wiki/MCX_connector
GSN 8400 manual here
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/GNS8400_OM_ForWeb.pdf
D
Nov 04, 2007 | GPSRD Radar Detector
Cant get it to work
If this is an IQue 3600 then you will need to install the Palm Desktop from your original IQue disk in order to sync with your new laptop. The Microsoft active-sync is for a PDA using Windows (Garmin M3 and M5 are windows based PDA w/GPS).
May 09, 2007 | Garmin iQue 3600 GPS Receiver
Navman iCN 520 GPS Receiver Logo
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
