Question about Aiwa NSX-D70 CD Shelf System
Cdrplayback i have lose my cdrplayback program and can't view my dics with out it can't re install have no dics to
Program new key fob for Cadillac cts 2003
There are several methods of doing this - but your 2003 requires that you either go to the dealer for them to add a FOB with special equipment (ask if they'll do it for free - can't hurt). If you have time to kill, you can do it yourself with Method 3 as described and found at:
Key Fob Reprogramming General Cadillac Forums
Method 3 - Key Fob Auto Learn
This procedure will first erase all known key fobs. The procedure will then program a single or multiple key fobs. Method 3 is a series of three 10-minute key cycles, for a total of 30 minutes. This procedure requires that you have a replacement key fob and the vehicle mechanical key.
Important: All previously programmed key fobs will be erased upon completion of the 30-minute programming procedure. The order in which the key fobs are programmed will determine its numbering position within the RCDLR memory. The first key fob programmed will be key fob #1, and the second key fob programmed will be key fob #2. The number stamped on the key fob case is for reference only: #2 can be programmed as #1.
Do not place any known good key fobs in the vicinity of the vehicle when programming with Method 3. If the RCDLR recognizes a known good key fob during Method 3 programming, the programming mode will resort to Method 1.
The vehicle must be OFF.
Place the replacement key fob in the console pocket with the buttons facing forward.
Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
The DIC will display a message: OFF/ACC TO LEARN.
Press the OFF/ACC portion of the ignition button.
The DIC will display a message: WAIT 10 MINUTES, then it will count down from 10 to 0, one minute at a time.
When the counter reaches 0, DIC will display OFF/ACC TO LEARN.
Repeat steps 5-7 two more times, for a total of 30 minutes.
A beep will occur and the DIC will display: READY FOR FOB 1. At this time all previously known key fobs have been erased. When fob 1 is programmed a beep will be heard and the DIC will display a message: READY FOR FOB 2.
Additional key fobs can be programmed by taking fob 1 out of the pocket and inserting fob 2. If desired, up to 4 fobs can be programmed. Once 4 fobs have been learned, the DIC will display a message: MAX FOBS LEARNED, and automatically exit the program mode.
If learning less than 4 key fobs, press the OFF/ACC portion of the ignition button to exit the program mode.
Operate the active portion of each key fob in order to finalize the programming sequence and verify correct system operation.
Feb 25, 2015 | 2003 Cadillac CTS
I have a 2005 buick lasabre custom that did not come with the DIC (driver information center)Can I purchase the dic and install it in my 2005 custom lasabre.
No. This is a part of the IPC and the vehicle configuration in the BCM would have to be changed, which, due to your VIN, will not allow for programming. The IPC is VIN burnt, as is the BCM.
Dec 01, 2014 | 2005 Buick LeSabre
Keyless entry remote programming
Hello here is the instructions for programming the key fobs
This procedure will add, replace, or invalidate all key fobs. This procedure requires that you have a known good key fob available, a new/replacement key fob, the vehicles mechanical key, and a scan tool.
Method 1 is also used for the initial programming of fobs to a new replacement RCDLR. In this instance, the new RCDLR comes ready to learn the first key fobs introduced. Perform the learn procedure as outlined, with the exception that the new RCDLR does not require a known good key fob be placed within the interior of the vehicle.
Note: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Methods 2 or 3 must be used in this instance.
  1. The vehicle must be OFF.
  2. Place a known key fob and any new/replacement key fob(s) to be programmed in the cupholder inside the vehicle. DO NOT place any fobs in the console fob pocket at this time.
  3. Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
  4. The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4). → If the DIC displays: OFF/ACC TO LEARN, the known fob has not been recognized. At this time, programming will revert to Method 2.
  5. If the DIC is displaying the correct fob number that needs to be programmed, skip ahead to step 9.
  6. If the DIC is not displaying the correct fob number that needs to be changed (i.e., the DIC is displaying: READY FOR FOB 3, and you wish to program FOB 1), use the scan tool to access the following: • Vehicle Control Systems • Computer/Integrating Systems • Module Setup • Remote Control Door Lock Receiver • Program Key Fobs
  7. Select the fob position you wish to program: Note: Selecting Invalidate All Fobs will erase any known fobs and will cause the DIC to prompt READY FOR FOB 1, requiring all fobs to be relearned to the vehicle.
    • Invalidate All Fobs • Program Fob 1 • Program Fob 2 • Program Fob 3 • Program Fob 4
  8. With the fob position selected, press the PROGRAM soft key on the scan tool. The DIC should display: READY FOR FOB X (X = fob 1, 2, 3 or 4, depending on the selected position)
  9. With the DIC displaying the correct fob position that is to be programmed, place the new/replacement key fob in the console fob pocket with the buttons facing forward.
  10. A beep will occur once the fob has been learned.
  11. If programming additional key fobs and there is no DIC prompt that indicates READY FOR FOB X, repeat steps 7 and 8.
  12. Exit programming mode by pushing the OFF/ACC portion of the ignition switch. Note: Failure to exit programming mode (press OFF/ACC) prior to pressing the UNLOCK button of each key fob programmed will result in that fob being inoperative. Pressing the UNLOCK button completes the programming sequence and is require to ensure transmitter operation.
  13. Press the UNLOCK button on each key fob that was programmed to finalize the programming and confirm system operation.
Nov 03, 2010 | 2006 Cadillac STS
What does a c on the dic mean?
Your vehicle has a Driver Information Center (DIC).
All messages will appear in the DIC display located
below the speedometer in the instrument panel cluster.
The DIC buttons are located on the instrument panel,
to the left of the instrument panel cluster.
The DIC comes on when the ignition is on. After a short
delay, the DIC will display the information that was
last displayed before the engine was turned off.
The DIC displays trip, fuel, and vehicle system
information, and warning messages if a system problem
is detected. The bottom line of the DIC shows the
shift lever position indicator. See Automatic
Transmission Operation on page 3-23
for more
information.
If your vehicle’s DIC has these features, the compass
direction and the outside air temperature may also
display on the DIC when viewing the trip and fuel
information. The compass direction appears on the top
right corner of the DIC display. The outside air
temperature automatically appears in the bottom right
corner of the DIC display. If there is a problem with the
system that controls the temperature display, the
numbers will be replaced with dashes. If this occurs,
have the vehicle serviced by your dealer/retailer.
The DIC also allows some features to be customized.
See DIC Vehicle Customization on page 4-66 for
more information.
DIC
Sep 05, 2010 | 2002 Buick Rendezvous
I DON'T HAVE LEGRIA HF R16 INSTALLER WHERE CAN I DOWNLOAD THE INSTALLER SIR.. I LOSE MY INSTALLER DIC 1 AND DIC2
try to visit the website of the your Digital camera.. Because I think they had it there for costumer used.
Aug 23, 2010 | Cameras
I have Microsoft Office 2003 on my Toshiba laptop PC, Windows home XP. A friend installed Microsoft Picture Manager, which I've been trying to uninstall but cannot. I don't find it in any programs that can...
Do a system restore. Click start, all programs, accessories, system tools, system restore. Follow the instructions to restore to a date prior to the install of MPM. You will not lose any new files but you may have to update your antipvirus program.
Aug 08, 2010 | Toshiba Computers & Internet
Driver information center (DIc) 2002 deville
you must get a key seeded at the dealer unfortunatly
Jul 11, 2009 | 2003 Cadillac Deville
Programming a keyless entry remote
Key Fob Auto Learn
Do not place any known good key fobs in the vicinity of the vehicle when programming.
Good luck and hope this help's keep me posted, there are 3 other methods and the 5th method is a tech 2 scan tool that the dealer uses but this should work on your year of cadillac.
Jul 01, 2009 | 2003 Cadillac Deville
Computer won't read camera or card
Do you have a suitable photographic program to view your photos installed such as Photoshop,Picture viewer or something? Have you installed any software onto your pc which was supplied with the camera? There is probablyl a compatible program supplied in this. Do not reformat unless you are prepared to lose your photos! Get a spare memory card to experiment with-one with no important photos on it! Make sure you install any camera software onto your pc.
Jun 11, 2009 | Fuji FinePix A360 Digital Camera
Aiwa NSX-D70 CD Shelf System Logo
55 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
