Question about Kenwood KDC-MP335 CD Player
How to get ipod playing through speakers
Ipod connection fits how do i get it playing ?
Go to standby mode and push the menu button, also the bass boost button and use the control knob to find the thing that says aux on and turn it on.
Posted on Feb 11, 2008
SOURCE:
FCan get my Ipod to play through my Roland TD-20 Mudule
You need to get yourself a cable - with a 3.5mm male jack plug on one end (which will fit into your ipod), and a 1/4 inch male jack plug on the other end.
(you could use a lead with a 3.5mm male plug on each end, and used a 3.5mm female to 1/4 inch male adaptor to achieve this)
Connect the 3.5mm end into the ipod - play a track, with the volume at say, 75%.
Connect the 1/4 inch end of the cable to the 'Mix In' input in the back of your TD20.
Use the 'Mix In' control - at the top right hand side of your TD-20 module to control the volume.
If you wish only to have the iPod going to (for example) headphones - and not Front Of House (PA) speakers - which you will have connected via the Master and / or Direct Out(s); this can be achieved in the 'Mixer' settings (accessed via pressing the 'Mixer' button).
Oct 22, 2012 | Roland TD-20X V-Drum Sound Modul
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
Shuffel and universal dock
you can't .... If you want to use the ipod to play music through a stereo system you will need a 3.5 mm audio jack and use this to connect.. but the shuffle will not hook up to a universal dock made for regular ipods
Oct 18, 2009 | Apple iPod shuffle Second Gen. Silver (1...
How do i play my IPOD through my sound system
get an approprate cable and connect in teh aux port of your music system
Jul 16, 2009 | LG Audio Players & Recorders
When trying to play the music on my Ipod it keeps reading format error. Why is it doing this and how can i get the music to play? Ehen I try to sync wiht windows media, it says did not fit on device.
MP3 files come in different resolutions try to load some different MP3's (from a diff source) and see if those work, they should. BionicSam
May 20, 2009 | Apple iPod touch
Videos wont play
1. go to "videos" on ur ipod
2. press "tv out" until u see off next to it
3.then go to "TV screen".. press wide screen
4.then press "fit to screen"
5.watch ur movie
Jan 28, 2009 | Apple iPod nano MP3 Player
My im600 is new but never charged my ipod. It played OK at first but the adapter does not charge the battery. The player does not play without the battery and then only for about 5 seconds. Is it just a...
First of all, did you fully charge the battery using the A/C adapter before initial use? If your ipod does not fit with any of the attachments correctly, try just placing it on the dock without the attachment & it should connect fine just be sure it's connecting to the dock properly. I have the ipod nano 2nd generation & the attachments don't work, but it fits on the dock well without the attachments & works great!
Jan 25, 2009 | Altec Lansing Inmotion-IM600...
Ipod connection
I don't believe there is an input on this boom box but if there is is should be on the back side and it should fit a 1.8 mm jack which plugs into the top of an ipod through the headphone jacks.
Dec 31, 2008 | Sony S2 Sports ZS-X3CP CD Boombox
Ipod touch connector
Hello serafineb,
The Alpine Full Speed cable for the iPod supports the following versions:
Fourth generation iPod
Fifth generation iPod
iPod photo
iPod mini
iPod nano
According to their website it does not appear that Alpine currently has a cable for the iPod touch. They do, however, make a "generic" cable for most MP3 players that connects directly to the earphone jack. Although this would not allow you to control the iPod from your stereo's head unit, you should be able to connect the iPod touch via this cable to play music through your car stereo.
More information about the "generic" cable can be found here.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 17, 2008 | Apple iPod touch
Kenwood KDC-MP335 CD Player Logo
104 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
