My is not working if i on my system his display is not working if it work after few second he hang otherwise restart automaticaly, if i restart the system same proccssing again dispaly not working system cpu is working only
Your computer totally in very condition but the problem come from your hard drive replace the hard drive and then try because when computer start and windows begins boot so its mean that the motherboard and processor are working properly
Firstly check the power is on. and then check the power cable should be woking. if it restart promlem then check the ram . maybe its ram prroblem.
As computer starts hold down F8 and youll see a safe mode. use the safe mode and it might just come back, restart it....sometimes strange viruses does this but i dought in your case.it should come up in safe mode allowing you to save your files ...folders to cd record disks...then you can format and reinstall all programs.
SOURCE: how to repair my system
Hi, the first thing to try is to make sure your craphics card has not worked loose. If this is still firmly in place then try a replacement card. When your system boots and hangs up it is usualy either RAM chips loose or failed and as you say the system boots ok then it will almost certainly be the craphics card at fault. Regards mistyman
