Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
1 Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
3 Click [Start] to begin initializing.
Initializing H10
A
A
B
B
thanks for the suggestion but the problem is that when i connect it to the computer it's not detected!!
doesnt detect iriver h10
i have lost the driver cd what do i do ow to conect it to a new computer
I have the same problem as Slavska. Comes up with system intitialising and just sticks there. Tried to format it via PC but the PC can't see the device. Help ......
the clock keeps turning when i turn it on i cant listen to my music
The H10 keeps initialising when turned on and does not go further. Requires reset to switch off. The computer does not recognise the MP3 player.
Have disconnected battery and tried again , which did not help.
also checked battery volts, approx 4.7 volts and charger.
