Question about Acer Computers & Internet
No operationg system - Acer Computers & Internet
  • Acer Master
  • 27,725 Answers
Operating systems not found
To resolve this issue, use one of the following methods, depending on your situation.
Contact your hardware manufacturer
Your best bet may be to contact the manufacturer of your computer or your hard disk.
The manufacturer may have a utility that you can use to perform a more detailed scan for damaged areas of the disk and help verify the correct BIOS settings.
However, be aware that the damage to your hard disk may be serious. Sometimes this means that your only solution is to replace your hard disk.
If a fix or workaround is not available, you can use the "Advanced Troubleshooting" section to try to resolve this issue.
Advanced troubleshooting
This section is intended for advanced computer users.
If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact support.
For information about how to contact Microsoft support, visit the following Microsoft Web site:
http://support.microsoft.com/contactus/
(http://support.microsoft.com/contactus/)
Method 1: Verify the BIOS settings Verify the computer's BIOS settings to make sure that BIOS lists and recognizes the hard disk. See the computer documentation or contact the hardware manufacturer for information about how to verify the BIOS settings.
After you verify that the computer's BIOS detects the hard disk, restart the computer, and then test to determine whether the issue is resolved.
If the issue is not resolved, or if the computer's BIOS cannot detect the hard disk, you may have issues with your hardware.
Contact the hardware manufacturer to inquire about how to resolve this issue. You may have to replace the hard disk.
For information about how to contact hardware manufacturers, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
65416
(http://support.microsoft.com/kb/65416/ )
Hardware and software vendor contact information, A-K
60781
(http://support.microsoft.com/kb/60781/ )
Hardware and software vendor contact information, L-P
60782
(http://support.microsoft.com/kb/60782/ )
Hardware and software vendor contact information, Q-Z
Method 2: Use Recovery Console Use the fixmbr command in the Windows XP Recovery Console to repair the MBR of the startup partition.
Warning This command can damage your partition table if a virus is present or if a hardware problem exists.
If you use this command, you may create inaccessible partitions.
We recommend that you run antivirus software before you use this command.
We also recommend that you backup your data before you use this command.
If the fixmbr command detects an invalid or non-standard partition table signature, the fixmbr command prompts you for permission before rewriting the MBR.
The fixmbr command is supported only on x86-based computers.
Posted on Aug 04, 2013
My asus fonepad disconects fro wifi every time its switched off
So do all the other computer systems.Their is a Operationg System setting to make it load automatically.
Aug 14, 2014 | Computers & Internet
I deleted my computers operationg system
Reinstall of Operating system is the complete solution for your PC.
Nov 01, 2012 | Computers & Internet
My hp mini 1000 hungs and i try formatting after dat it display system/system32 missing or file corrupt pls what do i do?tanks
it looks like you need to run your recovery discs to restore your system 32. altenativly.
format memory and re-install your operationg system and any service packs. ensure to save any wanted data beforehand.
I hope this was useful.
Jan 12, 2011 | Computers & Internet
Can not install Samsung SCX-4200 for scaner
hello check your operationg system and download suitable scanner drivers for your operation system
Aug 30, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Inspiron 1520 laptop shuts down while working.....now its not starting at all....please help.
check with ur BIOS, n POWER ON/OFF switch might be damaged.
or there must be damaged to ur operationg system, maybe damaged to the system's DLL files must be damaged r missing, it will done by a virus, or any illegal [programs.
try using a better anti-virus software.
n for ur problem, during next reboot, plz insert the valid OS cd/dvd into the drive, n
in the BIOS select BOOT from the CD.
then follow the instructions n then go to fixing of th OS.
hope u'll be definity fixed with it.
else try reinstalling the operationg system, b4 that create a valid backup of all the important documents in the system, in a separate external memory device, like pendrivve or a external harddisk,..thank u!!
Jul 17, 2009 | Dell Inspiron 1520 Motherboard
Computer wont load onto main screen
Simply fomat the hard disk, reinstore operationg system, and simply download drivers for installation from the ibm site.
Jan 09, 2009 | IBM ThinkCentre A50 PC Desktop
I have a dell inspiron 1501 and all the usb ports are not working , says failure
Since those ports are plug and play, there should be something wrong with the operationg system. Are you using Vista, if yes, you better use XP.
Dec 22, 2008 | Computers & Internet
Code
go to technician and ask him to reload operationg system of ur phone. if problem still stays in ur phone then it need to be repaired.mostly this problem gets solved with operatings system
Jun 13, 2008 | Nokia 1110 Cellular Phone
No sound, no volume controll icon in my computer
You need to install or re-install the sound drivers. To be able to download/install the appropriate drivers, you need to determine the brand/model of your motherboard and/or the sound card.
Pls post back with the brand/model.
Good luck and kind regards.
Dec 12, 2007 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
