Question about Zanussi ZWF1430W Front Load Washer
Zanussi washing machine
My washing machine model number ZWF1430W keeps coming up with a code E90. What does this mean and can I fix it
  • Anonymous Nov 09, 2008
    water can't come out by washing machine after washing in still in whole of tanks inside
  • Anonymous Mar 24, 2014
    Drum not rotating
  • 183 Answers
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Posted on Sep 01, 2007
SOURCE:
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Can anyone help ive got a zanussi FJDR 1466 W. e91
    I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
    Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
    Nov 02, 2009 | Zanussi ZWF1430W Front Load Washer
    Hi zanussi fjr 1254 w error code e90 what does
    This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
    Thanks
    Jul 01, 2009 | Zanussi Washing Machines
    Error Code E90
    it seems to be a common error code on some Zanussi models. This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts: Take the top off the machine, (ENSURE IT IS UNPLUGGED) and on the right hand side of the machine, you should see a set of 4 blue wires that go from the electronics module to the front display unit. Take this plug off (it is held on by plastic retainers) clean with wd40, or silicone (Servisol) contact cleaner, then dry, replace, then try again. If it is very badly corroded or pitted, you may have to replace that part of the wiring and socket.
    If it is not that, then the wiring to/from various other sensors could be damaged, or the control board could be faulty. It is probably worth checking around other plugs and sockets, re-seating each one in turn, that lead to the control board, as they are expensive (£60 - £80). Pulling off and plugging back on (Re-seating) the plugs and sockets has the effect of cleaning the contacts, and may fix certain intermittent faults like this. Obviously check for any plugs/sockets that appear burnt, corroded, or discoloured compared with the others, and clean the contacts with emery or a needle file.hope this helps pls do let me know
    Feb 09, 2009 | Zanussi ZWF1430W Front Load Washer
    Zanussi electrolux washing machine zwf1431w
    Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
    Dec 17, 2008 | Zanussi ZWF1430W Front Load Washer
    ZANUSSI ZWF1437W WASHING MACHINE
    yes sounds like door interlock cheap and easy diy job goodluck and unplug regards jason
    Jun 14, 2008 | Zanussi ZWF1430W Front Load Washer
    Zanussi washing machine wont spin
    check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
    Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
    Washer whilst washing keeps flashing up with E90
    Click on Zanussi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
    Nov 06, 2007 | Zanussi FJS1225W Front Load Washer
    E90 Error Code
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
    Zanussi ZWF1430W Front Load Washer Logo
    1,055 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    jimorris77
    Marvin
    Marvin
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
