Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
USB doesn't work
When I plugged in the interface at the beginning it had worked but suddenly stopped work and now is recognized by the computer but the usb lead (purple) doesn't appear, only the two first leads of each side (-20 and -40). there is no signal in my computer software (cubase) and i don't know what the problem is.
  • Anonymous Jan 24, 2009
    After installation, it works brilliantly but Every time i turn my computer off and turn back on the Lambda does not come on with the Computer.
    I have an Imac and Running BootCamp with Windows...
    HELP
    help much appriciated
    [email protected]
  • 818 Answers
Can be the driver, download from here
http://www.lexiconpro.com/ProductDownloads.aspx?ProductID=8&Type=0
Sergio
Posted on Mar 10, 2008
SOURCE:
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
IPhoto stopped recognizing my camera. iPhoto was working until yesterday and now it doesn't. Image capture recognizes the camera but does not give the option to import. The USB port works. The hard...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto.
Sep 30, 2011 | Panasonic Lumix DMC-FX3 Digital Camera
I have a 500 GB Seagate portable external hard drive model 9ZA2AH-500. It was working fine untill yesterday. Now when I plug it in all I get is a faint beeping sound Then it stops. I have tried plugging it...
It may be the interface that has failed but I suspect the hdd has failed.
Take the hdd out of the case and fit another drive. If that one is OK the hdd is dead. If it doesn't work, try a new usb to SATA interface.
Sep 25, 2017 | Seagate Free Agent Go Small 12 GB USB...
My m-audio fast track usb interface has been working but all of a sudden lately my computer recognizes it when I plug it in but the interface will not pick up a signal from a direct line or from a mic so I...
Hello, try going into Sound & Audio Settings through control panel. From there, click on the Audio Button. Toward the bottom on the left, UNCHECK the box that says 'USE ONLY DEFAULT DEVICES'. Then Under RECORDING section, pull down the drop menu and select M-Audio. And Click APPLY & OK to close. I would reboot and it should be working after that.. ok? Good Luck & PLEASE DON'T FORGET TO RATE MY SUGGESTION, OK? THANK YOU :)
Oct 19, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
My Alesis stopped working!!
it might have a fuse in it if not its prob. an amp inside
Dec 27, 2009 | Alesis io 2 Portable 2-Channel 24-bit...
I can't get my computer to recognize my Garmin 255w on USB cable.
Change the mini usb cable. Some mini usb cable are for charging and not data. It happen to me and used the externo hard drive usb mini cable and zapppppp my computer nows read the gps and gave it a drive (h:\). hope it works for you.
Jul 15, 2009 | Garmin nuvi 255W GPS Receiver
My computer doesnt recognize my mp3 player
the problem maybe is the usb card of your pc... maybe the usb loose...that why sometimes when the mp3 when you plug in recognized then suddenly stops..or maybe your mp3 has a virus and maybe the pc too.usually the mp3 is plug n play.
Oct 13, 2008 | Coby MPC895 MP3 Player
EZ201 Rca Small Wonder Camcorder
Make sure you have the latest version of USB on your computer. I just purchased a Small Wonder EZ101 on ebay and it connects to my laptop without a problem.
Jan 12, 2008 | RCA EZ 105 Camcorder
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
178 people viewed this question
Top Lexicon Computers & Internet Experts
Tony Raia
Alun Cox
Thomas F. Schneider
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
