Question about Abit SG-80 Motherboard
Dvd ram drive stopped working
I have a acer aspire 3050 laptop,and my dvd ram drive has stopped working keep getting an error code 39 can anyboby help
    President:
  • 1,257 Answers
Follow this article to fix the issue:
http://support.microsoft.com/kb/314060
Posted on Apr 23, 2009
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 18, 2008
    President:
  • 2,961 Answers
To long winded to post the solution, click below for info http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on Sep 01, 2007
SOURCE:
My Acer Aspire cd /dvd drive isn't operating properly. I keep getting error message that I have no driver.
many cds/dvds get dirty by fingering on the reading side of them, use tops(ear-cleaners) to remove dirt from lens.
Apr 05, 2012 | Computers & Internet
My acer aspire 3050 is swiching on then is looking to load up then switches back off and will keep doing it ?
check the ram memory and if it seam to be ok ..try to reinstall windows..It may have a damaged windows and this is the cause for not completing the boot ..
Aug 07, 2010 | Acer Aspire 3050-1733 Notebook
Acer aspire 1600 four error code on pre boot then
Please reseat your RAM, and your CPU. Also check that the CPU is locked tight and that the RAM is seated properly. Run off A/C without battery then test with Battery only then with A/C on and battery connected.
May 22, 2010 | Acer Aspire 1604LC PC Notebook
I keep getting error code 0xC004E002 and the description says The software licensing service reported the license store contains inconsistent data....I am not that good technologically and I really need...
probably ur ram is faulty..replace with a standby n see..
also check for defective capacitors on the main/mother board..
reinstall os..
dis also do happen when ur cd/dvd rom drive is down or the cd frm where u r installing is corrupted..
the above often take place with some error message(s)/blue screen..
but if there's no such displaying, esp if hangs/stops/power off during installation, it may b caused by the main/mother board or even the battery..
..contact ur system admin/vendor....
Oct 29, 2009 | Acer Aspire 4730-4516 Notebook
Pioneer DVR-K17RS ATA ACER CODE=39
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Mar 28, 2009 | Acer Aspire 5610-4648 Notebook
Drivers for acer aspire 3050
There you go... hope it can help you.
http://cr.am/framed.php?url=http%3A%2F%2Fsupport.acer-euro.com%2Fdrivers%2Fnotebook%2Fas_3050.html&ref=driverguide
Jul 09, 2008 | Acer Aspire 3050-1733 Notebook
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
Jul 01, 2008 | Acer Aspire 5610-4648 Notebook
Hi How old is this laptop? If it is brand new, then you should be able to send it back to acer. Its the problem with drive or mainboard not with the drivers.
Thanks
Mar 16, 2008 | Acer Aspire 5610-4648 Notebook
If you can't restored the driver, you should reload the operating system using Alt+F10 or using disks (not from windows, boot from disks)
In your case, it's look like you can't access the dvd in windows, i hope you can access in dos mode.
Jan 20, 2008 | Acer Aspire 3680 Laptop
Abit SG-80 Motherboard Logo
89 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
