Question about HP Photosmart 2575 All-In-One InkJet Printer
Hp 2575 printer
I have a pc with windows vista home prem.i am using a bt home hub which works fine.the problem i have is after a few weeks of using the printer the printer icon vanished and now i cannot use the printer.i have tied to reinstall the drivers from the disk but when it gets to the final stage a red cross comes up saying it cannot load the drivers .my router sees the printer and both my kids laptops work and print fine via wi fi ,they also run vista.hp are no help as this has gone on for months and bt say its not them as the hub sees the printer.it insalled ok first time i fitted the printer so i no the virus/firewall is not blocking it .hp pinged the system and it found the printer but try as i might i cannot install the drivers please can you help
  • grancal Dec 01, 2007
    I have had a 2575 for about 18 mths and get the "USB not connected" all the time - even when the computer accepts the install. I originally had an XP but have bought a HP pavilion running Vista and have the same problem. On complaining to HP some months ago, a Technician rang me consistently to try all sorts of solutions which I didn't understand, but did as instructed. It did not make any difference. I bought a C3180 and had the same problem with the XP but have not tried that yet with the Vista. I like the 2575 and would like to use it. When first installed on the XP it worked on & off for a few weeks when the fancy took it, but since then it will not scan or work properly with photos. Printing and copying is fine! What now?
Barret, I tried this link but doesnt work for photosmart 2575. thats only for HP Photosmart C6180. thanks
Posted on Dec 10, 2007
    Scholar:
  • 21 Answers
Hi, I have a good news that this issue can be easily solved and HP has released a patch to fix the issue. Just download and install the patch below: =========== http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-54112-1&cc=us&lc=en&dlc=en&product=1153494&dlc=en&lang=en ============ IN the download page click on the download only button and save the patch to the computer and then install it to the computer in network that you are facing the issue with.. Once the patch is installed try to add the printer by searching it in network and then the issue will be resolved. Hope this will work for you. Regards Barret.
Posted on Sep 27, 2007
SOURCE:
Www bt com mypin
the should be a pin code in the back of the hub that you put into what you want to connect to the internet with and a admin pass so you can change the setting in the hub to let what you are using use the hub and try doing a reset the is a small pin hole in the back of the hub push a pin in for a few second to re set that works sometimes.
Jan 27, 2014 | Microsoft Windows Vista Home Premium...
Can I connect my HP PSC1510 to my BT Homehub v1?
yes, you can. I have my printer connect to my hub and my desktop and I can print from my laptop wirelessly.
You will need your all in one connected via a printer or USB cable to a computer AND also connected to your hub. Then, go to the computer that is connected through a cable to the all in one. Your all in one should have some way to configure its IP address. I have my printer configured as 192.168.1.4 and it's plugged into the 4th port of my hub. Check if this works.
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have an HP Photosmart 2575 and the message "refer to device documentation" appears when I try to scan. (Printer stopped scanning with installation of updated operating system) I use Mac OS X version...
The printer scan button wouldn't work for me either. I had to install the HP Solution Center software from CD onto my Windows Vista PC then I use its scan document software button to do any scanning.
Feb 26, 2010 | HP Photosmart 2575 All-In-One InkJet...
Can't install to Vista HP PSC 1210
I'm a bit confused about which printer you are using so here are the driver links for both:
HP PSC 1210:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90764&lc=en&cc=us&dlc=en&submit.y=10&submit.x=7&lang=en&cc=us
Select the Vista OS and download.
HP 2575:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441240&lc=en&cc=us&dlc=en&submit.y=9&submit.x=4&lang=en&cc=us
Same as above, choose Vista OS and download.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | HP Photosmart 2575 All-In-One InkJet...
HP PhotoSmart 2575
hmmm..sounds like a new set of drivers might be just the thing.
get em here
Mar 05, 2008 | HP Photosmart 2575 All-In-One InkJet...
Scanjet 6300c
Check HP's website to see if there is a driver. Otherwise you may be out of luck.
Feb 15, 2008 | HP Scanjet 6300c Flatbed Scanner
HP Photosmart 2575 All-In-One InkJet Printer Logo
224 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
