Question about SanDisk Sansa E280 MP3 Player
Transferring Music from Napster w/o WMP
I have a Napster to Go subscription and my Sansa E280 shows up in Napster but I can't figure the process of downloading music out! With my Setting on MTP, I "transfer" music from my Napster library to the MP3 player. Disconnect it. Turn it off. Turn it on. The files are not visible on the player! Napster did successfully transfer them however. I then change my Settings to MSC. Re-connect the player to my laptop, open up WMP 10, and the files "Sync" somehow - I actually am not even telling it to. Disconnect. Turn off player. Turn on player. Change Settings to MTP. Now all the music I downloaded in the first place is there and playable. Please simplify this process for me. I can't do this every day! Before I wrote this, I wiped all the files off the player -- reformatted the player in both MSC and MTP modes. (e.g. out of WMP and just in MTP mode.) Thank you for helping me...
  • 33 Answers
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downl...
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Feb 10, 2008
SOURCE:
My sansa is showig up the message synchronize to continue music subscription
When you use a service like Rhapsody or Napster and download "unlimited music" as part of a subscription, you periodically need to sync the player to prove that you are still paying a subscription fee, or the subscribed music will not play. Just sync the player (plug in with the USB cable) to a PC which has a valid subscription to the service that you use. Make sure you log into the service before you sync so that the new keys are picked up.
If you have a subscription to a service that has gone out of business (Like Yahoo Music Unlimited), you may just need to delete the subscription music from the player.
Mar 12, 2011 | SanDisk Sansa e250 MP3 Player
Have a Sansa Fuze, a friend downloaded some music but it will not play, I get this message, "synchronise to continue your music subscription". what does it mean? thanks for your help
Perhaps the music your friend gave your was from a subscription-based service? It could also have DRM so the music knows it is not supposed to be on your MP3 player. Either way, those two situations mean the music is digitally protected from copying.
Other than that, perhaps there is a setting the needs to be switched and resolved through your synching of the device. Did you personally start a subscription based music service for you Sansa?
Mar 02, 2011 | SanDisk Sansa E280 MP3 Player
Do I need to download any special software to use my new mp3
I'm no expert, but we have both an iPod and a Sansa mp3 player, and I prefer to use Napster with my Sansa player. It's a monthly subscription (about 15 bucks a month), but you can audition the entire song and download as many as you want to your computer or your player. With iTunes and the iPod, you can usually audition just the first 30 seconds of a song and then have to pay 99 cents foreach one you want to download. it. Napster has access to a huge library of music, and you can also just select (without downloading) whatever mix of music you want and use Napster as your personal radio station. The one downside of Napster is that you have to maintain your subscription or you won't be able to play the music you downloaded to your player. Good luck.
Dec 09, 2008 | Electronics - Others
Mp3 Player - sansa sandisk 2 GB
Unfortunately you are not going to be able to go online to sync your device...All music subscription such as napster and rhapsody require you to sync your device every single month using their actual software..The reason is to prevent customer from cancelling their music subscription..once you cancel your membership all the songs you have on your device will become useless.In another word, you are renting the music from the subscription company...
P.S.Please rate accordingly...
Thank You
Computerrep
Jun 17, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Synchronize to continue your music subscription???????????
You need to renew your Napster memebership - unfortunately, there are no permanent freebies with that music svc - must constantly renew
Apr 27, 2008 | SanDisk Sansa c200 MP3 Player
Needs to sync
When you first synced your Sansa Clip to the initial computer, you probably synced it (knowingly or not) with a music subscription service such as Napster or Yahoo. If the subscription has since expired, you will get this message. Alternatively, if you tried connecting the Sansa player to another computer which does not have the aforementioned music service, the Sansa player wants to verify that your subscription to the service is still good. The best solution is to hook the player up to the original computer, and resync it with Napster or whatever music service you were using by opening that music service's program. Most of the time, when you connect the Sansa player to Windows XP, Windows will prompt you: Windows will ask what you want to do with the device. Instead of "Take No Action," just sync the player with Napster (or whatever music service you have a subscription to) - Windows will give you this option. If you music service subscription has expired, a more deatiled process may be required which falls outside of the scope of this solution. Try this suggestion first - if it fails, e-mail me back (don't send me a personal e-mail - reply through the FixYa website - I want documentation of everything).
-Tha Mp3 Doctor
Feb 04, 2008 | SanDisk Sansa Clip MP3 Player
Synchronoze to continue music subscription
I treat my Sansa like a disk drive and simply transfer the files from my hard drive to the Sansa via Explorer.  The tracks purchased from Napster can be downloaded to your hard drive.  Then I exit Napster and use Windows Explorer to simply transfer the data.  Works great for me for the past month!
Aug 22, 2007 | SanDisk Sansa e250 MP3 Player
"Synchronize to continue your subscription"
I did a search on "synchronize to continue your subscription" and found this solution on another forum. I tried it and it worked.
"Just changing the sansa transfer mode will fix this issue: If the Sansa player shows MSC, change it to MTP: 1. Eject the device and unplug it from the computer.
2. On the device, push the Menu button.
3. Go to Settings > USB.
4. When you see 2 settings, Auto Detect and MSC, select Auto Detect. (Auto Detect causes the Sansa player to use MTP whenever possible.) Decatur."
Aug 14, 2007 | SanDisk Sansa E280 MP3 Player
Pink Screen Synchronize to continue your music subscription
Renew your Rhpasody or Napster subscriptions and reload/resync the songs - those two service shave fixed-term licenses
Apr 02, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
114 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
