Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows drivers how should i install my pic of my mobile in computer???????
Windows Xp PC ran Logitek web cam perfectly on Skype until PC was upgraded with MS Media Player 11 now when Skype is selected the PC reboots! Skype recommended updating all drivers. Windows searched and this was done fine until the Realtek Audio driver was replaced when message Code 10 fault came up and there was no audio at all on the PC. Audio returned when I reloaded the Realtek Audio off of the original Gigabyte motherboard CD. Audio for all programs is fine except Skype where reboot problem no exists. Help would be appreciated. Sincerely David Bradley
Posted on Sep 01, 2007
SOURCE:
Perihale blootooth driver
To resolve this issue, you will need to install the device driver for your Bluetooth device. If the device came with a CD or DVD containing device drivers compatible with your version of Windows, insert that disk into the disk drive and follow the instructions to install the driver.
If your Bluetooth device did not come with a driver installation disk, you will need to go to the device manufacturer's website and download and install the latest driver for your device. To do this, go to the hardware manufacturer and search on the latest version Bluetooth driver for your device. Follow the instructions.
Windows 7 Compatibility Center
Windows Mobile Devices
If youre using a Windows Mobile device, follow the steps below to updte to the latest version of Windows Mobile Device Center 6.1
  1. Go to the Microsoft Windows Mobile Device Center 6.1 site
  2. Click Continue.
  3. If prompted, download the Windows Genuine Advantage software.
  4. Click Download, then click Run.
  5. Follow the onscreen instructions to install Microsoft Windows Mobile Device Center 6.1.
  6. Click the Start button, type device manager in the Search box, then click Device Manager.
  7. Expand Unknown Device, right click on Bluetooth Peripheral Device, then click Update driver software.
  8. Click Browse my computer for driver software, then click Let me pick from a list of device drivers on my computer.
  9. Select Bluetooth radio from the list. Under Company name choose Microsoft Corporation, then under Drivers, choose the latest version of Windows Mobile-Based Device Support.
  10. Click Next. If any warnings should appear, click Ignore, then when prompted, click Finish.
  11. Restart your computer.
Nov 09, 2013 | Lenovo Computers & Internet
Hi, I can't get my scanner conected, it was conected, turned it off ,now can't get it to work. ion PIC2pc. Thanks Nan
Hello.
Be certain that you followed the step-by-step instructions (From ION Support):
1. Turn on the computer.
2. Insert the installation CD into the CDROM
drive and the installation menu will appear. *
3. When you see the installation menu, click Install Driver.
4. Follow the on-screen instructions.
5. When the driver installation is complete, click BlazePhoto to install the software.
6. Follow the on-screen instructions.
7. If your computer does not have DirectX 9.0 or greater or Adobe Reader, click those items to install them. (If your
computer is using Windows XP Service Pack 2 or higher, Windows Vista, or Windows XP Professional, this is not
necessary.)
8. Click Exit to close the window.
Note: The first time you connect PICS 2 PC to your computer, wait a few seconds until you see a dialog box
that says "Found New Hardware" (this means the computer recognizes the PICS 2 PC). After you see this,
PICS 2 PC is ready to use.
If you followed the above instruction and still have a problem, reinstall (first, Remove from Add/Remove Programs) the software and be certain that the USB cable is snug.
If your computer is not recognizing the ION PIC2, be certain that your computer has a USB 2.0 port. Check your Device Manager to verify what USB port.
If still a problem, what error message(s) are you getting ? What operating system software (Vista, Windows 7, etc.) ?
Hope this helps.
Jun 28, 2011 | Office Equipment & Supplies
My computer does not detect the usb mobile for the phone. it tell me there are no driver
There can be many reasons for not detecting USB mobile to the computer. It can be off driver problem.Even if you have installed driver you need to look whether its capable of windows you are having. If the particular driver doesn't support your windows it shows no driver or not installed properly. So while selecting driver you should install according to the windows you are using.
Secondly you need to look whether your USB port is working or not. In other cases some phones have their own softwares to connect to PC or Laptop. So in that you need to have that mobile software installed in you Computer EX: NOKIA PC SUITE for Nokia Phones.
Make sure you look all these things carefully .
Thanks.
May 20, 2011 | Computers & Internet
Installed driver kodakeasyshare m863, cannot load pics to computer, says driver did not install properly. when I install driver again, it says it was successful. I try again to load pics and get same...
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 30, 2010 | Kodak EasyShare M863 Digital Camera
My sound card was accidently deleted , I was wondering what kind I need so I can re install it
follow this dell link
  • http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R91865&formatcnt=0&libid=0&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=119690
How to Install Dell Inspiron 9200 notebook ATI Mobility Radeon 9700... This step-by-step guide describers how to obtain and install Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP drivers for Windows.
1. Define your Dell Notebook device model.
2. Define your operating system to install your Dell Notebook device. Note: Update Drivers in Win Vista
3. Browse Notebook Drivers.
4. Find Dell Notebook Drivers.
5. Select Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP.
6. Download Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install Dell Inspiron 9200 notebook ATI Mobility Radeon 9700 Driver Windows XP.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
Jun 05, 2010 | Dell Inspiron 9200 Notebook
Usb driver not installed in my computer
the usb driver should be there in the mother board disk, Normally phones require drivers to be installed. You can always google for it.
Jul 10, 2009 | Computers & Internet
How do you get the pics off the camera??
Have you installed the drivers? If not, install the drivers on your computer from the supplied CD ROM. After that, the PC will recognize the camera.
Feb 09, 2009 | D-Link DSC-350 Digital Camera
How do I download photos ?
Use Windows Explorer (START, right click and select Explore).
First connect the mobile too the USB cable and connect that to the computer. You should get a message like "New Hardware detected" or something to that effect.
Now go to Windows Explorer. Scroll down the left panel until you see a new drive corresponding to your mobile. It will be the drive after your DVD/CD ROM. It will usually be titled "USB Mass Storage", or if you have installed your mobile drivers, it will display your mobile's name.
Click on the (+) next to this and expand the contents. Open the folder that contains the pictures and highlight each one you want to copy by holding down the CTRL key and selecting each pic. Now right click on any of the highlighted pics, select copy. Browse to the folder in your PC where you want to copy the pics, and right click and paste,
Hope that hepls!
May 19, 2008 | Samsung i760 Black Phone
HOW TO TRANSFER PHOTOS FROM MY MOBILE TO PC
Use Windows Explorer - START > right click > Select explore.
Once you have connected your camera to the PC, and after it has been detected (you may need to install camera drivers fro some models, if it doesn't get detected) , open Windows Explorer as explained above. Now scroll down on the left panel until you see the entry for your camera. Click the (+) next to the entry to expand. Scroll down to the appropriate folder and copy all the pics you want to transfer. (right click, copy. For multiple selections, hold down the CTRL key and click on the pics you want one by one)
Now select the folder where you want to copy the pics to, and right click -paste them there.
Of course, will have to have installed the camera driver first in your PC, or sometimes the camera may not be recognized.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 07, 2008 | Cell Phones
Uploading pictures off of my my razr3c
Try To purchase A Driver Cd Of Your Phone from any Retail Mobile Shop. or Download it form Motorola Web site, It Takes More time. If Your phone not detacted on pc please try to use another usb cable. and it detect please install Driver cd and enjoy.....
Apr 29, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
103 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
