Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
System not booting
\windows\system32\config\system file is missing
Re: system not booting
ITs not a solution but im having this problem and for whatever reason when i hit f10 it brings me to PhoenixBIOS Setup Utility
Posted on Aug 23, 2008
    Problem Solver:
  • 6 Answers
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears. The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console . NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CDs, press the R key to open the Recovery Console. NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
    1. Turn on the PC, and press the F10 key repeatedly at the first screen.
    2. At the Recovery screen, click Advanced Options .
    3. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
  4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: diskpart
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
    • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
    NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered. For more information, refer to Performing a Full System Recovery in XP .
Step 2: Replacing the file from a backup folder Use the following steps to find and replace the missing file from the command prompt environment: NOTE: The following steps use the filename Ntoskrnl.exe. If the filename that appears on your computer is different, replace Ntoskrnl.exe with the filename from the error.
  1. Type the following at the command prompt: cd X:\i386 (where X is the main drive letter)
  2. Press the Enter key. If the error The system cannot find the path specified appears, enter the following paths, in order, until the error does not occur:
    • cd X:\Windows\i386 (where X is the main drive letter)
    • cd X:\i386 (where X is the main drive letter)
  3. Type the following at the command prompt: expand ntoskrnl.ex_ X:\windows\system32 (where X is the main drive letter) If your filename is different, replace ntoskrnl.ex_ with the filename that appears in the error and replace the last character in the filename with an underscore (_).
  4. Press the Enter key, and type the following at the command prompt: cd X:\windows\system32 (where X is the drive letter)
  5. Press the Enter key, and type the following at the command prompt: attrib ntoskrnl.exe -r
  6. Press the Enter key, and type the following at the command prompt: rename ntoskrnl.exe ntoskrnl.bak
  7. Press the Enter key, and type the following at the command prompt: rename ntoskrnl.ex_ ntoskrnl.exe
  8. Press Enter and type the following at the command prompt: exit
  9. Press Enter and the PC restarts without the error. If the error persists, continue to Step 3.
Step 3: Replacing boot.ini if necessary If the error continues, preventing you from opening Windows, the boot.ini file is probably corrupted. Open a command prompt and replace the boot.ini as follows by typing: copy X:\windows\pss\boot.ini.backup X:\boot.ini (where X is the main drive letter) After the boot.ini file is replaced, restart the PC. Step 4: Recovering the PC If the error still continues, recover the PC .
Posted on Nov 16, 2007
Take windows xp cd and repair from the cd
Posted on Sep 01, 2007
0 characters
3 Points
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
Aug 09, 2012 | Microsoft Windows XP Professional
File:\windows\system32\config\system file is missing or corrupt laptop : sony vaio
boot you computer using OS CD and at first screen use recovery console command prompt
at command prompt
wait for 10 second and the enter your administrator password
then go to c:\windows\system32\repair
the type copy system c:\windows\system32\config
press y to overright file
and restart your computer
Nov 23, 2010 | Operating Systems
My acer notebook says windows could not start because the file is missing or corrupt \windos\system32\config\system. How do I repair it without a drive to download windows xp onto the computer?
Well i got a trick, i get into other xp notebook or pc and get rid of it of copying the missing file from others, to find that missing file into that address, then burning on the CD, while booting, that he have the file.But that is a file that he trail for configuration of the operative system, but is missing.Sometimes is file that is gone lost from someplace or is delete by bad malware.If you have recover, your lucky to have one.
Nov 11, 2010 | Operating Systems
I can't open windows xp i got this message:\r\n"unable to read file C:\windows\system32\config\software " I tried to fix it thru recovery console copying the i386 file but nothing happenned Help me please
hi You need to get a Windows XP from someone and follow these instructions: Windows could not start because the following files is missing or corrupt \WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD. 2. At the first R=Repair option, press the R key 3. Press the number that corresponds to the correct location for the installation of Windows you want to repair. Typically this will be #1 4. Enter in the administrator password when requested 5. cd \windows\system32\config 6. Depending on which section was corrupted: ren software software.bad or ren system system.bad 7. Depending on which section was corrupted copy \windows\repair\system copy \windows\repair\software 8. Take out the CD ROM and type exit
Aug 28, 2010 | Microsoft Windows XP Home Edition
Error says file: systemroot\system32\config\system
Can you boot into Safe Mode? Restart the computer and hit the F8 key continually until you get to the Advanced Boot options and choose Safe Mode. Here you can run System Restore. If you can't, then boot off of the Windows XP CD and get to the Recovery Console. Here you would type in chkdsk /f/r and hit enter. The Check Disk utility will try and fix any errors in the file system.
Mar 19, 2010 | Operating Systems
C:\windows\system32\hauurjab.dll is missing on my
Just google the error msg and you'll find the solution for it. At most times, ppl recommend you to delete this particular registry file that is associated with this dll file. But if I were you, i would better reinstall the operating system. Just google the error and give a try. Best o'luck.
Hope this helps, If so, rate me.. ,thanks - billa
Sep 05, 2009 | Microsoft Windows XP Home Edition
Windows/system32/config/system is corrupt
One of following will work:
Mar 20, 2009 | Microsoft Windows 2000 Professional for PC
I have deleted svchost.exe from windows xp
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Dec 02, 2008 | Microsoft Windows XP Home Edition
Sam file
Use the windows installation disk to perform a repair install.
Or a alternative way would be to start the windows setup and then start the repair console when asked to.
then copy the c:\windows\repair\sam file to c:\windows\system32\config\
May 16, 2008 | Microsoft Windows Xp Home Edition English...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
369 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
