Sara, it sounds like you have come close to burning out the clutch.
SOURCE: Heavy smoke when you first start the engine
Hi. sounds likes too much oil in engine or if you tilt the mower up&down or side to side.
if you need more help, just write again
SOURCE: my troy built 210 6.75 hp mower self propelled mow...
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
