Question about Gateway FPD1530 15" Flat Panel LCD Monitor
FPD1530 Power light blinking, display seems not to be on. Can't seem to do anything with the buttons on front. How do I get this Gateway FPD1530 diplay working?
  • Anonymous Dec 04, 2007
    hi,
    I have the same problem and have traced it down to a bad backlight inverter control chip, I just need the IC, the back light, power supply both work fine in another unit, just need the inverter control card or source for the control chip..
    thanks
Gateway FPD1530 Backlight turns on, but no display
has to do with power i can get myin to stay some times but then the same thing hapens to me u have to buy a new power board wich is esy to replace and i have had min as a second screen for like 4 or 5 years now with no probloms so its just from over use..
Jul 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Installing monitor problem
The Gateway FPD1530 is plug and play and should be automatically detected by the Operating System. In your display properties it will say plug and play monitor as Monitor type.
Jan 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Toshiba 57h81 red light blinking
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 14, 2017 | Toshiba 57H81 57" Rear Projection...
FPD1530 15in flat screen Config. issue
The native resolution of the monitor is 1024 x 768, so set your computer resolution to that value. If necessary, restart the computer with the monitor powered on.
Here's a link to the User manual:
Gateway FPD1530 User Manual Fpd 1730 Specifications
Nov 19, 2017 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway fpd1530 15in flat
There are more than one inverter circuit for this model. One is prone to have poor solder connections in the transistors Q8 & Q10.
Another can be repaired by replacing 2 1uF electrolytic capacitors near the center edge of the board between the lamp sockets.
Monitor Mike
Nov 15, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
GATEWAY LCD MONITOR FPD1530. UNIT SHUTS OFF IN ONE SECOND WHEN TURNED ON, EVEN WITH XP SOFTWARE TURNED ON.
Hi...there,
It's seems your backlight inverter are busted... need to replaced a new one or repaired it.
Aug 21, 2008 | Gateway FPD2275W LCD Monitor
Gateway fpd1530
Not sure about these screens but they should be button on the front that says auto. Press this and the screen should set itself up optimally. Usually does but I have not seen one of these before
Mar 07, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
FPD1530 monitor - no display
I recently fixed 4 fpd1530's with the problem you describe. The fix is to replace capacitors c105 and c106 located on the left side of the power supply board. Both are 1 microfarad 50V parts. The fpd1530 is very easy to work on. Total repair time after initial diagnosis averaged about 10 minutes.
Dec 25, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
"Processing Auto Configuration" keeps showing up on my screen.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
By
Murugeshkumar.k
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
182 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
