Question about 3Com (3C16593BN) 24-Port Ethernet Hub
3com 24-port all lights are not on
Some computers are not connected
  • ppnartey Aug 26, 2008
    on the switch the number corresponding to the horizontal cable in the patch panel has the activity lights on, but the computer is still not able to connect to the network
  • 20 Answers
Need more information please
Posted on Sep 02, 2007
SOURCE:
3Com Baseline Switch 2024 - Switch - 24 ports duplex light blink continusly
Is it hsappening with all the 24 ports or with some ports ?
Might be an indiacation towards the duplex mismatch.
are you getting CRC errors on the interfaces ?
Dec 05, 2010 | 3Com Baseline Switch 2024 - Switch - 24...
Some of the ports are flashing. some are not
Typically non flashing port lights means that there is nothing connected to those ports and no communication is happening. data movement and communication fires off the lights.
Oct 14, 2010 | 3Com 3C16985B /REF3COM SSII 24-PORT SWITCH...
My 3com 4200 28 ports is restarting by itself many
Base from the description of your problem its only showing that some of the port on of your Ethernet switch is already getting bad and this usually happen on switch like this and eventually all port will go bad and will lead to the replacement of the device. With this type of problem you can first try to adjust the speed of your network card to 10 half duplex and check if that will correct the connectivity problem and if it does its just a sign that sooner or later the device is already getting bad and since its only a switch there's no firmware that we can load to it or even a reset button to bring the device back to its default settings.
Jan 27, 2010 | 3Com 4200 24-Port Ethernet Switch
3Com 3c17304 port 25 up not connecting
Well I think the port is bad, I had one that did something similar to your problem. I got on the 3Com website and submitted and RMA request and they upgraded my with the newest model. But if yours is still in stock they will replace with the same type. That is what I would do. Hope this helps ya.
Feb 25, 2009 | 3Com SuperStack 3 4228G 24-Port Ethernet...
Hub not working properly
Maybe your hub port is not using auto sense port.
Aug 30, 2008 | 3Com (3C16593BN) 24-Port Ethernet Hub
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Jul 25, 2008 | 3Com 4500 24-Port Ethernet Switch
Link and activity lights on 3Com Switch ports without connection
Do the ports work when the cables are connect?  I did some re-search and this seems to be an ongoing issue with 3com switches.  It should not effect the use of the switch
Oct 09, 2007 | 3Com 3C16985B /REF3COM SSII 24-PORT SWITCH...
Anyone seen ths before?i
when it flashes it usily means its connected if it dosent work at all you should get a new hub
Aug 30, 2006 | 3Com 3C16985B SWCH 24-PT 10/100 3300XM...
3Com (3C16593BN) 24-Port Ethernet Hub Logo
144 people viewed this question
Top 3Com Computers & Internet Experts
john smith
didi2005
Håkan Sterner
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
