Question about Indesit WA 115 Front Load Washer
Wia111 Machine lights all come on as usual but it wont fill with water the door is shut properly and when i set the program machine clicks as if its going to fill but doesnt.
    President:
  • 1,294 Answers
First check whether your inlet valve is open on the wall; if that is not the problem check to see that the inlet valves are not clogged with some dirt or something, clean out and refit. Plug off the wall and careful with the water spillage. The final part should be to check whether the water flows into the machine, ie. the entry at the soap dispenser. Simple.
Posted on Sep 01, 2007
SOURCE:
I have a indesit iwb71250 that the red door lock light is on constantly but we can open the door and shut although the machine will run it wont fill with water... any ideas
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Oct 19, 2014 | Indesit IWB71250 White 60 cm Washer Front...
My indesit washer wia111 starts to wash but once it has done the main wash and goes to rinse the machine stops working and the red door lock indicator goes off
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into and run the program to finally drain shut off and open lock. . If this does not happen then the voltage at the valves,motor and pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 26, 2011 | Washing Machines
Washing machine initially wont run any programe / only drains, fills with water but does not turn drum. Have checked door switch is faulty, now wont run at all.
Kindly replace the door lock and check it everything will be fine before that kindly check whether the belt of the machine is properly fixed
May 17, 2010 | Washing Machines
Hotoint WMA34 door light keeps flashing and machine wont start
The light flashing usually indicates that the door is not closed securely. this can be caused by a weak or broken door handle spring.
If you are satisfied that the handle is o/k, then the other possibility is that the control module has a blown track, this can be accessed by removing the top cover.
Hope this nhelps.
Jan 15, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The machine is not filling and all the display lights are flashing.Thankyou.
It sounds like ether youre plumbing is not leting water down the pipe or the valves have gone inside youre washing machine try filling the washing machine up via the powder dispensing draw with the front door of the macine shut and the macine off when the machine is full of water swich it to the program you want and see if it works if it does then its the valves in the machine burt before you do that unhook the filling hose from the wall and see if water is coming out if not its youre plumbing
Nov 27, 2009 | Office Equipment & Supplies
Indesit wia111 no lights come on when switched on at powerpoint
Make sure you dont have it set to soak. if you click the timer one click at a time, does the wash/mach. do anything like wash:spin:drain etc. check that door latch for power out once closed. difficult to diagnose without all the facts
Jan 27, 2009 | Indesit W 123 Front Load Washer
My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
Hi just trying to solve a similar problem. My machine would turn on but would not fill. It could be that your cold water filter is blocked. If no or reduced water pressure then the machine will not operate correctly. Take off back panel and you should see the filter assembly. GIve this a clean and see what happens.
We have 14 of these dishwashers and so far they have all proven to be very reliable machines. This is the first issue in 4 years.
Paul
Aug 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Power Surge and WD16BA
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Indesit WA 115 Front Load Washer Logo
210 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
