Import flip video to iMovie and edit flip videoWhy choose Mac Flip Video Converter for import flip video to iMovie?If you recorded a few video clips with the Flip Mino or Flip Ultra, and when you tried to import the video files from flip video camcorder to into iMovie or tried to edit the flip videos, only to find out that you couldn't. Apparently, you're not alone, because you'll find there are plenty of other people with the same problem.
First:Flip video's built-in software Flipshare can combine clips or editing flip videos,but the editing function is so less for the flip users.
Second:iMovie has different versions, each version has more or less difference, the video formats they can support has its limitation, it only supports mov, dv, hdv,MPEG4, etc. But for the flip camcorder(include the Flip Ultra, the Flip Ultra HD, the Flip video Mino, and the Flip video Mino HD) just produce flip video in mp4 or avi format, avi flip video can't recognized by iMovie, so converting flip avi to the formats compatible for iMovie, you can import your flip file to iMovie without any difficulties.
With all the problems above,what can we do to import flip video to iMovie?-Introduce a best flip video to iMovie converter for mac,which can let you import your flip video to iMovie without any difficulties
Mac flip to iMovie converter is a program specially designed to make Flip Mino and Flip Ultra work well with iMovie, iTunes and QuickTime, it can convert flip video to various common formats like mpeg4, mpeg2, mov, dv that compatible with the iMovie, mov for QuickTime.
Edit flip video in iMovie - Import flip to iMovie and edit flip video iMovie.
Part one: How to import flip video to iMovieHD/ iMovie 08 /iMovie 09 with mac flip to iMovie converter.Step 1.Free download,install and run flip to iMovie converter
Step 2.Set an output format
Choose 'MPEG-4' for iMovie 09, iMovie09 supports the most popular video formats like AVCHD and MPEG4, and even the new iFrame video format.
Choose 'MPEG-2' for iMovie08, iMovie08 works with many tapeless camcorders that record to flash memory, HDD,or DVD media.
Choose 'DV' for iMovie HD."
Step 3.Set a destination for the converted flip video
Click the "Open" button in the main interface of Flip Video to iMovide Converter,and the choose the destination as you want.
Import flip video to iMovide with Flip Video to iMovide converter
Step 4.Step5:Start the conversion
Click "convert" button to start converting flip video to iMovie with mac flip to iMovie converter.
Part two: Edit flip video on iMovieNow your flip videos have been converted to iMovie supported video formats. Launch your iMovie and follow the steps below to edit your flip videos:
Step 1.Trim video length
You are able to get any part of the source Flip to iMovie converter for mac by specifying the exactstart and the end time by dragging the slider bars. Thus, when you are trying to convert flip video on mac, you could casually limit the video or audio film's length according to your own will.
Step 2.Crop video
Select one video clip, click "Edit"->"Effect" and click on the Crop button to crop it.
Step 3.Adjust video
Click "Edit"->"Effect",and set the brightness,saturation,contrast as you like.You can also set special video effects including old film,grayand emboss to adjust flip video.
Tips:
1. This
flip to iMovie converter mac support batch conversion to save your time and trouble, you can load many flip files at the same time, besides it can merge your separated flip files into a succesive one by click 'Merge into one flie'button.
2. Flip to iMovie converter supports instant preview both input and output video effect, it provides two priview windows for you to watch what you have modified, in addition, interesting pictures can be captured from playing video.
