Question about Goodmans GMP33005 MP3 Player
Complete veg i own the goodmans gmp33005 and within a two week period it quit i have reset the unit a few times and now its a complete veg. non responsive i wonder maybe i put too big of a demand on the little fella or its just plain junk my computer wont even recognise the thing anymore its not bad for the money but now i look at it as spice one would say money gone is there still hope for this unit and if so what exactly would i do to bring it back to life since then i have been to uxcell .com and found aworthy replacement can i get a little help or is it just spare parts for a new device
Learn how to construct sentences for a start, and maybe throw in some punctuation rather than expecting me to read nearly 150 words with 1 full stop !! Oh, and to fix your GMP33005, turn it off, press and hold the reset button with a pin for 5 seconds then plug it into your PC. When the drive autoplays, or appears in explorer, right click on it and go to 'Format..'. This will delete everything and return it to its original state when you bought it.
Posted on Sep 13, 2007
SOURCE:
My 2001 Kenmore microwave model # 665 6065200 completely quit working today.
It'll be the main fuse on the inside.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Microwave Ovens
Goodman a2410 airhandler wiring diagram
i dont quite understand, it does not start at all or it sometimes starts and some other times it doesnt?
Aug 09, 2013 | Heating & Cooling
Outside unit doesnt start inside unit is working
This model of Goodman A/C the condenser coil get extremely dirty and what happens is when your condenser runs for a long period of time it pops the capacitor. This is the starting component for the compressor and the fan outside. the coil needs to be cleaned with a non acid condenser cleaner. Open up the side compartment of A/C look at the silver cylinder thats the capacitor if is looks swelled replace it.
May 11, 2011 | Goodman CKL30AR30 Air Conditioner
U-line UC02175 water inside pooling under veg drawer, icemaker supply turned off, no water in catch pan inside back
Well sounds like your ice maker evaporator drain hole is frozen, every time the unit goes into defrost cycle, water backs up and leaks down to the drawer. You can try turn off the refer for 48hrs with the doors open, most case it will reset by it self. If it is happening again in few weeks, then you evaporator drain pan heater is not working. Also make sure the doors are shut all the time.
Feb 03, 2010 | U-Line CO2075F-B Echelon Refrigerator Ice...
Goodman HVAC Package Unit
Cycling the external switch on the GMS series will not help you. That switch is for A/C only. At the unit found inside the house, remove the front cover. If there is a door switch, tape it closed. Now if the thermostat is calling for heat, the unit will cycle as you mentioned. When the unit does not start, check for a blinking light on the circuit board. After three unsuccessful tries, the light will blink a code (2 blinks then a pause up to 9 blinks than a pause). Make a note of how many blinks you see. On the reverse side of the access panel you will find a diagnostic schematic. It should tell you a fault code corresponding with your blinking. This will give you a starting point where to look. If the codes are not found there, check inside your owner's manual. Or you can call Goodman at 713-861-250.
Get back to us with those codes and maybe we can help you further.
Oct 30, 2007 | Goodman GMS90703BXA Heater
Goodmans GMP33005 MP3 Player Logo
62 people viewed this question
Top Goodmans Audio Players & Recorders Experts
Pavel Pranovich
Pavel Pranovich
Tom Chichester
Larry
Are you a Goodmans Audio Player and Recorder Expert? Answer questions, earn points and help others
