Question about Amana DRS2462B Side by Side Refrigerator
Ice maker constantly revolving.
Ice maker had small leak, fixed it. Put the ice maker back in the freezer and it won't make ice. The teeth simple keep revolving slowly. They never stop at the 2:00 position. I do hear a click, but not sure if it's the solenoid or not. Could this simply be a matter of the freezer not being at 17 degrees or lower? Perhaps something blocked in the water supply tube? Any other ideas? Thanks.
  • mps_smith Sep 07, 2007
    There was a leak in the tray that I fixed with some silicon adhesive. Not sure it's going to stick, but it should. It's not near any moving parts.
    As stated above, the teeth (arms or whatever) that push out the ice cubes just keeps going round and round for days. No ice, no water, no luck.
    Not sure what the temp is in the freezer, but you'd be hard pressed to get a spoon more than a half inch into the ice cream. The temp was set to 6 out of 7 for 4 days with 0 luck. It's now set at 4 out of 6. Finally lifted the bar to get the icemaker to even stop trying.
  • 291 Answers
How cold was it before, you fixed leak?, its got to reach a certain temp before it will activate.... what temp is it now? DOnt know what u did to fix leak.. is there anyway u might of bond up ice maker?
Posted on Sep 03, 2007
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
Ice maker does not dump makes ice but it will not dump need for someoneto tell me how to fix
check the gears on the motor doubt the teeth are stripped best fix is order a NEW ice maker complete.
Jul 17, 2015 | Samsung RB195ACPN 18 Cu. Ft. Bottom...
Ice maker leaking into ice tray making icebergs
The icemaker could need seal replacement. Check with an appliance parts supplier.
Apr 14, 2014 | Maytag M1TXEGMYB 20.6 Cu. Ft. Top-Freezer...
No ice
If ice is formed but will not drop just pour hot water over the cubes. Or the teeth that push out the ice are getting stuck, in that case hold down the on switch to advance the teeth manually.
Apr 27, 2013 | Freezers
Kenmore side by side ice maker not working, water does work, checked the back not a frozen line. The problem occurred when the compressor/start device was replaced in the summer. The repairman said that...
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Hope it help you.
Have a nice day.
Dec 06, 2010 | Kenmore Refrigerators
Amana, bottom freezer, freezer not freezing and then refrigerator not keeping cool.. help Started with the ice maker not making ice, the sound of trying to pull water but never any ice. Then the freezer,...
Hi
Firstly put off the refrigerator before the compressor burns off.
The problem is simple... the coling gas has leaked out.... put new coolong gas...BUT only after finding the place of leak... this will be needed to be fixed first.
Regards
Berry
Feb 07, 2010 | Amana ABB1927DE Bottom Freezer...
Ice maker is not making ice. water line is fine. with door open and flapper held shut, the sensor light is constant.
I just finished with this problem and found it to be a bad ice maker itself. The back sensor part shorted out. Replacing it is easy and price is 185.00.pricey but very simple.
Nov 07, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leak from freezer
Two possibilities. Water leaking fro ice maker or the drain is blocked behind the back panel inside freezer. I will send links soon on how to fix it. Sea Breeze
Jul 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker leaks with or with out power on the far right side
The water valve (or solenoid) that only lets the water through from the water supply line when the ice maker calls for it is leaking you have to replace it.
May 02, 2009 | Thetford Norcold RV Cooler/Freezer
Amana DRS2462B Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
