Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Problem with XP
When i install XP first time my resolution goes to 800 x 600 pixels and colour quality to Medium (16 bit), and this forces me to install my grahics driver, instad of normal XP lookup?
  • Microsoft Master
  • 12,061 Answers
Ya can adjust your settings to suit ya maximum resolution of ya Video card.. Always ensure you have most up-to-date "Drivers" for your exact type of card. The link below show one how to adjust resolution. www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx
Posted on Sep 01, 2007
  • electronic & computer repair&  servicre
SOURCE:
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
I can't change screen resolution on Lenovo L171 Monitor.It is set on 640 by 480 pixels and 16-bit color quality.I entered the properties options in Control panel>Appearence and Themes>Display and...
The problem is not your monitor, it is your computer. It sounds like the computer is operating off a standard vga driver that comes with windows. You need to locate and install the specific driver for your onboard chipset or add-on video card. I would be more specific but you haven't posted any info on your computer.
Apr 13, 2017 | Lenovo L171 17" LCD Monitor
How do I change my computer monitor to 1680 x 1050?
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig. below, click on the settings tab at the top right of the box.
The areas worth noting are: google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.
Changing the ResolutionTo change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Jan 13, 2011 | Computers & Internet
To improve the colour bits
It is possible that you do not have the correct drivers installed/available for the graphics card, try using the drivers i have found on the intel website, the link below
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=6107&ProdId=1065&lang=eng
Jun 26, 2010 | Intel D845GVSR Motherboard
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
Hi,Have 710n when powered up shows "not optium mode" box and cant get into menu.How do you access menu? Many Thanks Bruce
In Your Desktop, Right Click -> Properties. In this Display Properties window, Click on Settings Tab.
Adjust the screen resolution to '1280 by 1024 pixels'.
Set Color Quality to 'Medium (16 bit)'
Then click on 'Advanced' Button. In Monitor Tab, Set the Screen Refresh rate to 60 Hertz. Click Apply/Ok in both the settings windows. This will Solve your Problem. Else, Try setting Color Quality to 'Highest (32 bit)'.
Oct 16, 2009 | Samsung 710N V2 17" LCD Monitor
We can't get our screen resolution back to what it was (1024x768) it changed when a game being played ended. It runs on 800x600 at the moment and everything is too big.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
Screen Resolution
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.Changing the Resolution
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
Aug 05, 2008 | Computers & Internet
Viewsonic monitor
Pixel Ratio is just a parameter Measured to Produce Good Quality Display with Fine details so Do not Mix up with Resolution and Pixel ratio.
Use the Resolution that best sutes the Application you use(which may change with time to time based on applications you use)
Keep a standard Resolution 1024 x768,or which ever suits your Vision.
NViiDiA is a Grafix card and Monitor features are 2 differnt thigs so.
Dont be concerned about the Parameters and get mixed up.
just find the best possible Resolution and enjoy your Monitor with best Quality, :)
Jul 17, 2008 | ViewSonic VX924 19" LCD Monitor
Default monitor
Sounds like you need to install your video card drivers, to get the resolution you need.
Jan 06, 2008 | Computers & Internet
Unable to install the canon Software
Under your control panel in "Display" go to the settings tab and slide the resolution bar to:
Screen resolution: 1024 x 768 pixels or more,
Color quality: Medium (16 bit) or more
That should do it.
Dec 06, 2007 | Canon PowerShot S5 IS Digital Camera
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
