I think you are saying that when the gas valve is turned on, gas flows out of the carburetor and onto the ground. If that is correct then the float valve in the carb is stuck. This is not a big thing to fix.
Take the carb off the motor and turn it upside down. You will be removing four parts so be sure to put them back in the same positions they were when removed.
Remove the float bowl at the bottom of the carb.Inside there will be a float. There is a little "float needle" under the flat tang of the float. This needle has some trash in the seat that will not let the needle close properly. Remove the long pin that holds the float in place then set the float aside along with the needle. Now clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Now put the carb back together and install it on the bike.
This should fix the problem.
Please rate this answer. Thanks raytzpralph!
