Solution #1
posted on Apr 02, 2009
Rank: Apprentice
Rating: 75%, 2 votes
Generally your camera will have a main menu, which lists this as an option.
Look for a menu button on your digital camera. While the camera is on, press this button, and cycle through the options that appear, watching for a listing which says something like "Erase all".
Usually there will be another button or set of buttons that have arrows on them, and let you move up and down among the listed options. Press the up or down button (or the right/left button, whichever applies to your camera), until the "Erase all" option is highlighted.
There should also be a button on your camera that says something like "Ok" or "Function Set"; no matter what it's called, the important thing is that it is NOT one of the buttons which either opens the menu listings (the one I'm describing as the "menu" button, regardless of what your camera calls it), or moves between menu items (the up/down/left/right buttons). Once you have found the menu item for "Erase all", and have highlighted it, press this button.
You will probably get a message asking you to verify your choice, since once the photos are deleted from your camera, you won't be able to retrieve them, so most cameras will ask you to confirm any erasing you do, whether it's just one picture, or all the pictures in your camera's memory/storage. You confirm the deletion by pressing the same button that you used to start the deletion process.
So, to recap:
1) Turn the camera on.
2) Find and press the "Menu" button.
3) Find and press the arrow/next button until you see a menu item saying something like "Erase all".
4) Find and press the "OK" button -- or whatever button will get the camera to accept the menu item selection you've made.
5) If the camera asks you to confirm your choice, use the arrow/direction keys to highlight the "Yes" or "OK" option in the confirmation window.
6) Press the same button you used to start the process ("OK" or "Function Set"), one more time to confirm your choice.
7) The camera should now delete all of the photos in its memory.
WARNING: DO NOT DELETE YOUR PHOTOS UNTIL YOU'VE DOWNLOADED THEM, UNLESS YOU ARE ABSOLUTELY SURE THAT YOU'LL NEVER WANT THEM. It is always better to have an extra backup of your pictures than to permanently lose something you can't replace.
If anyone else has used the camera, it's best to check with them to make sure that they've downloaded their pictures off of the camera, before doing a full delete of all pictures on the camera.
Most cameras will also let you individually delete pictures that came out badly, or where you accidentally took a picture you didn't mean to take. If you're not sure what else is in the camera's memory, it's always wisest to use this method, instead of deleting all the pictures at once.
